Subframe???
Old Nov 3, 2006
Civicman1988's Avatar
Subframe???
Thre D17 subframe has holes in it do i need the holes to pull wires threw or can i weld them shut? Thanks
Old Nov 3, 2006
Rufus's Avatar
Why would you want to weld them shut?
Old Nov 3, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
Don't weld them up, they're speed holes. They add speed.
Old Nov 3, 2006
How do they add speed?
Old Nov 3, 2006
You've never seen the Simpsons...?
Old Nov 3, 2006
Rufus's Avatar
lol the real question is how are they affecting you so much that you need to consider filling them?
Old Nov 4, 2006
2k2civic's Avatar
Ya, no reason to fill those holes. They are probably there because of something during the manufacturing process (possibly to set up the pieces on a jig while they get welded together), but I doubt you will gain anything by spending the time to fill those, unless of course you've got OCD and it helps you sleep better at night...
Old Nov 4, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
actually it will make your car slower... wanna know why??
Cause by doing that it will ADD wieght to your car... if anything you want to put more holes to reduce weight.. lol... j/k
Old Nov 4, 2006
2k2civic's Avatar
Ummm, yes, i doubt that the added 1-2 pounds will slow down your car very much. Your car is slow to begin with.
Old Nov 4, 2006
dru106's Avatar
ThE CoRRupToR
OO OOO!!!!! I got 2 subframes for sale!!! Just pay for shipping and im serious!!
Old Nov 4, 2006
civic01vtec's Avatar
First of all, it would be a waste of time. Secondly, welding on the subframe could weaken it.
Old Nov 4, 2006
civic05acer's Avatar
civic05acer has a spectacular aura aboutcivic05acer has a spectacular aura aboutcivic05acer has a spectacular aura about
no i want to know why would you weld them shut? answer?
Old Nov 4, 2006
exactly whose car are you referring to?
Old Nov 4, 2006
kasimmmmm's Avatar
sarcasm owns you.. lol he was joking about adding speed...
welding them or not welding them will not make any difference. You can go ahead and weld if you want to, but what are you trying to acheive though if you dont mind me asking? They are there so its easy to handle them during the manufacturing process.
Old Nov 4, 2006
The only reason I would want them closed is because sand gets in them because of where I live...Which sucks when I'm working under the engine and I accidentally hit the subframe and get a facefull of sand.
Old Nov 4, 2006
I just want the subframe to look cleaner at car shows and there is a lot fo housing being built by me and theres dirt all over so i dont want a face full of dirt when i work on them
Old Nov 4, 2006
HondaLuver's Avatar
Its a celebration bitches!
are you refering to the alignment holes?
Old Nov 4, 2006
HondaLuver's Avatar
i second the motion. better not be talking about my car...
Old Nov 4, 2006
when the subframe is sitting on the ground, the holes facing up. If u look on in ur engine bay by the intake theres holes right down there
Old Nov 5, 2006
I think i am going to fill them for looks
Old Nov 6, 2006
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
I saw somehwere on speed channel tv where they welded the holes shoot and fill the subframe with that expanding foam for stiffness
Old Nov 6, 2006
Not a bad idea i might try that
brainwashedmc
Jul 27, 2015 10:05 PM
fordover
Jul 11, 2015 09:10 PM
bgoetz
Oct 1, 2004 05:49 PM
SoNiCcIvIc
Feb 19, 2003 05:12 AM
nytejade
16
Dec 4, 2002 01:42 PM
