Transmission swap post information/Questions about automatic to Manual Transmission swaps
What manual transmission do I have in my 2001 LX coupe?
Old Apr 20, 2020
EM2-EMMA's Avatar
I’m a guy. My car’s name is Emma.
EM2-EMMA is an unknown quantity at this point
What’s the code/name specifically? I can’t find it on wiki 😂
Old Apr 20, 2020
FRSam's Avatar
Click Here
Re: What manual transmission do I have in my 2001 LX coupe?
It's an SLW
May I ask why you're looking for such information?
Old Apr 20, 2020
EM2-EMMA's Avatar
Thanks.
Im looking to see what can be done about the shortness of my gears and getting lower rpm’s and (slightly) better gas mileage in 5th @70mph
Anything? Or back to a shortcoming of the Civic? 😂
Which I’m okay with, but I thought I heard something about swapping 5th gear
Old Apr 20, 2020
FRSam's Avatar
Click Here
I'm pretty sure the HX has the longest 5th gear but the difference is so small it's unnoticeable. 100% not worth the effort.
Old Apr 20, 2020
EM2-EMMA's Avatar
Anyone else had any experience with this?
It might not be doable but I was just seeing
Old Apr 20, 2020
FRSam's Avatar
Click Here
Just got the specs if you're interested.
LX 5th gear is 0.711
HX 5th gear is 0.710
For reference as to what this means, it's how many (in this case, 0.710 and 0.711) rotations of the driveshaft to one rotation of the front wheel. As you can see, there is almost no difference.
Old Apr 21, 2020
EM2 (EX model) have the shortest gearing
Old Apr 21, 2020
Colin42's Avatar
You can swap in an ex trans and get shorter gearing for quicker acceleration, change the clutch while you're in there
Old Apr 21, 2020
BrotatoChip's Avatar
Super Moderator
HX and LX have the same 5th gear but the HX has a significantly longer final drive. At 70 mph the LX would be around 2850 RPM, the HX would be around 2200.
Old Apr 21, 2020
EM2-EMMA's Avatar
Right. Nice, I might look into swapping for an HX trans then. When I do my JDM motor swap
Old Apr 22, 2020
Super Moderator
Keep in mind this will make acceleration slower. You wouldn't need to shift into third gear until 90 mph.
https://www.civicforums.com/forums/1...smissions.html
Old Apr 22, 2020
EM2-EMMA's Avatar
Oh wow. Okay. HX is more for comfort then, I guess.
I went online and found a transmission parts store and almost found the solution. Will an Integra 5th gear fit in my LX tranny? Because when shopping on that website I found MY LX 5th GEAR for SLW, but it also said fits 3rd or 4th gear for Integra.
https://www.transmissionpartsdistrib...-1-7l-hon-14a/
Old Apr 22, 2020
EM2-EMMA's Avatar
I could be confused but it sounds like Integra 5th gear is a longer drive. Unless it just isn’t compatible.
Old Apr 22, 2020
Colin42's Avatar
They were built for fuel efficiency......
Why?
The transmission will worth more than the car after you get it back from the transmission shop
Old Apr 22, 2020
FRSam's Avatar
Click Here
Dude, just drive the car as it is. It's not worth the money or effort you're looking to put into it.
Old Apr 22, 2020
EM2-EMMA's Avatar
Yeah I get that the transmission idea is a little too much.
heeltoehonda
Apr 13, 2013 03:38 PM
horacioarce
Sep 15, 2003 07:06 PM
opto_isolator
Jul 9, 2003 05:32 PM
Gshockbreaker
May 3, 2002 01:57 PM
vasilli69
Feb 27, 2002 08:57 PM
