Turbo Post information/questions about Turbo here!
Turbo Civic Problems
Old Nov 18, 2019
2002Civc's Avatar
2002Civc is an unknown quantity at this point
Exclamation Turbo Civic Problems
Of course I wanted to cheap things out because I am just like that. But now im running into a simple issue. While installing my turbo i noticed the clutch slave cylinder is in the way of the intake of the turbo. So when installing I took it off. Is there any way i could position the slave cylinder differently if i bought another rubber boot. or does it have to be positioned in another way. or could i buy a smaller slave cylinder? i also can't find the turbo forums if there is any so sorry about that.
Old Nov 18, 2019
Re: Turbo Civic Problems
7thgen > engine performance modifications > forced induction
I'll go ahead and move it over for you
Old Nov 18, 2019
Colin42's Avatar
No, you need to move the turbo
Old Nov 18, 2019
Buuuutttt.. cheap and turbo.. eh... Not a good mix. Frugal and turbo, sure, but making sure you have quality components.
Truth of the matter is it sounds like the runners of the turbo mani were fabbed up to make the turbo site far too close to the block.
Old Nov 19, 2019
mac25's Avatar
Dr Krieger of Modification
Can you clock the turbo so it works?
Old Nov 19, 2019
clocking the snail will only help with the outlet, not the inlet, if anything. I remember my D17A2 turbo setup and the inlet was reaaaaaaallly close to the slave cylinder boot. It was really frustrating getting the inlet pipe on the snail's intake.
trev0006
Sep 27, 2005 03:34 PM
ricergribbs
Feb 10, 2004 09:54 PM
Voiceofid
Sep 25, 2002 10:09 PM
TWISTA
May 27, 2002 06:19 AM
