Turbo Post information/questions about Turbo here!
Turbo project questions
Old Oct 19, 2019
CIVIC RACECAR's Avatar
CIVIC RACECAR is an unknown quantity at this point
What's up EM2 or rather 7th Gen Family!?
Long time reader, new poster, sorry if I am posting in wrong section.
EM2 d17 turbo project currently in the works and I need your help friends!
Looking at:
- Hondata KPRO RSX 5 SPEED w/ CAM GEAR
- Larger Fuel Injectors (I need help, which do I get and are they a direct replacement?)
- Do I need a new Fuel Injector Rail?
- Upgraded Fuel Pump (Not sure what to look for, I see a few in the $40 - $60 range)
- Intake Manifold (Some people say the plastic intake manifold for the d17 can take up to 15psi but do not recommend over 10psi due to the plastic warping)
I might just keep the stock intake manifold, cheapest cast iron intake manifold is $500 and I am already way over budget on my EM2...**** adds up lol)
- Turbo Kit has everything but downpipe (Only downpipe I could find was one that gets rid of the catalytic converter, don't know how loud that is going to be on my custom catback setup w/ silencer)
Any input at all would be greatly appreciated!
Peace
CIVIC RACECAR IS RACECAR CIVIC
BACKWARDS
Old Oct 19, 2019
Re: New to Forums
  • - Larger Fuel Injectors (I need help, which do I get and are they a direct replacement?)
    • RSX-S injectors are a drop in (same electrical connectors and everything). Forgot how much boost they'll support up to. I know they're about 90-100cc/min higher flowrate than OEM. They are a bit taller than d17 injectors, so you'll have to account for that (longer bolts, spacers, etc). I have a set that's been laying around if you wanna go that route. IIRC, OEM is 230cc, RSX-s is 320cc. Otherwise, Deatschwerks injectors have been the go-to for higher flowrate injectors. WRX ones, methinks. Also, look into converting to a return-style fuel system with a good FPR, depending on how much boost you're intending on running.
  • - Upgraded Fuel Pump (Not sure what to look for, I see a few in the $40 - $60 range)
    • Walbro 255lph has been the pump of choice in the D17 world. About $100 last I checked. Currently $85 on Amazon
  • - Intake Manifold (Some people say the plastic intake manifold for the d17 can take up to 15psi but do not recommend over 10psi due to the plastic warping)
    • Custom might be the way to go. Either that or a D16Y8 mani retrofit. That 10-15psi "limit" does sound about right.
  • I might just keep the stock intake manifold, cheapest cast iron intake manifold is $500 and I am already way over budget on my EM2...**** adds up lol)
    • You right tho. lol
  • - Turbo Kit has everything but downpipe (Only downpipe I could find was one that gets rid of the catalytic converter, don't know how loud that is going to be on my custom catback setup w/ silencer)
    • idk if Random Technology is still in business, but they made the best aftermarket downpipe for the D17, catted, no less. Ran that with a boosted d17a2 back in the day. Then again, the turbo setup I had, the exhaust outlet was made to mate up with the OEM DP
@piano55man has a lot more recent experience with D17 boosting than I do.
Lastly,
Old Oct 20, 2019
Colin42's Avatar
Re: New to Forums
Welcome!
Old Oct 20, 2019
GolNat's Avatar
Prelude Owner
Re: New to Forums
Welcome.
I think people have used SRT-4 injectors also.
Old Oct 22, 2019
Re: New to Forums
Lastly,
Thanks!
So the RSX-S Injectors should be good for like 9psi of boost huh?
For the fuel pump what do you think about this? It's super cheap and the knockoff Walbro one is like $8 cheaper than this one:
https://www.ebay.com/itm/KEMSO-340LP...4/151914630279
It should be good right?
Welcome.
The OEM SRT-4 injectors? Is it plug and play?
Old Oct 22, 2019
Re: Turbo project questions
eh.. for something that's a direct contributor to engine health, I wouldn't cheap out.
Old Oct 22, 2019
GolNat's Avatar
Prelude Owner
Re: New to Forums
https://www.civicforums.com/forums/7...options-2.html
Don't cheap out on important stuff.
HemiRemington
Jun 24, 2010 08:44 PM
ricergribbs
Sep 20, 2004 12:02 AM
v8eaterokv6
Engine Swaps
Jan 6, 2004 10:24 PM
CaseysGuy385
Feb 18, 2002 12:50 AM
