Dynoed the monster
Dynoed the monster
Well, we figured out what the big problem was last time.... emanage had VTEC set too high, it would basically come on at the redline, and we never noticed it.... move the engagement point down... poof, power. (more explainations later... I've got dyno plots of no vtec, you can see what happens.
1st gear is useless.... it lights both tires at 5500. 2nd and 3rd are just nuts, I really haven't gone past that.... it was kinda busy.
Edwin (skipbarber) went with me... I'll let him post up his crap, but his HP curve was quite amazing (you could have put a ruler on it).
OK... here's no VTEC. We had to cut it off at 6K because the injectors maxed out.
As you can see... VTEC + Boost = 50HP
Boiler do you have any clue what your doing? Because looking at your dyno's it appears not. You have an EX why are you using the emanage to control Vtec? Why is your Vtec set at 5600? Your vtec should be controlled by the ecu not the emanage. Its costing you alot of power! And how do you figure your injectors are maxing out with 171 flywheel hp? Looks like another case emanage used incorrectly.
It wouldn't let us go below the 5200 we set it at without fighting
Second, its pretty easy to figure out that the injectors maxed out.... all you gotta do is look at the injector map. Since you seem to be so well versed in e-manage, surely you would have known that.
What size injectors are you running?..... There is a definate learning curve going from NA to turbo. NIce job so far. And I agree with a few more tweeks you should be able to hit 200+whp.
How much boost and what size turbo??
I agree with these guys. Your tuner probably didnt know the vtec in these cars is different. Just let the stock ECU deal with it, its set pretty much optimally anyway. You can set the emanage to not do anything to the vtec, at best just dont wire vtec up to it. Nice numbers though. Bet its fun to drive!
Honzy
Jun 25, 2015 06:28 PM
