Engine Management Post information/questions about Engine Management here! It's especially important for Forced Induction (Turbo and SuperCharging) and Engine swaps! What destroys engines are fuel management!
Emanage Full DIY Install-NEW UPDATE 9/30/05
Old Jan 21, 2007
  #91
gmcuajo's Avatar
gmcuajo can only hope to improve
Any of you have a VTEC head swap and using the e-manage to set vtec?
I have an e-manage installed in my car some time ago (D17A1). I did the VTEC head swap but can't activate the vtec solenoid. I try with different settings on the jumpers and swithches. But it doesn't work.
I just have the "VTEC out" (blue wire) connceted to solenoid. The "VTEC in" (yellow) and "VTM" (purple) are disconnected. I test the vtec with a switch and it works perfectly.
Settings that I tried:
--#1--, I have this before the vtec, I try it with the vtec. No vtec.
4-8-D
JP1 1-2
JP2 1-2
JP3 1-2
JP4 open
JP5 open
JP6 open
JP7 1-2
--#2--,
4-8-D
JP1 1-2
JP2 1-2
JP3 2-3
JP4 1-2
JP5 open
JP6 open
JP7 open
--#3--
4-8-E
JP1 1-2
JP2 1-2
JP3 1-2
JP4 open
JP5 open
JP6 open
JP7 1-2
--#4--
4-8-E
JP1 1-2
JP2 1-2
JP3 2-3
JP4 1-2
JP5 open
JP6 open
JP7 open
P.S.
I search but can't found...
Old Jan 22, 2007
  #92
gmcuajo's Avatar
Originally Posted by ncirom2003
well my ecu is for my lx so no vtec pins, ill have to use the emanage itself to engage the vtec so im wiring it straight to the solenoid, the only issue now is do i splice that directly to vtec out or vtm
Can you or someone solve this problem? I have the same situation now, swap the heads and have to engage the vtec with the e-manage (in a lx)...
Old Feb 7, 2008
  #93
GIOSAFAT's Avatar
GIOSAFAT is an unknown quantity at this point
Re: Emanage Full DIY Install-NEW UPDATE 9/30/05
Originally Posted by DaRk_MauL
Hey,
with the info in the greddy manual and andyman his info made this
update diagram.hope this will help some.
Hi guys...there are ok for e-manage ultimate??? or are only for the blu?
Can help me with e-manage ultimate?
Old Feb 7, 2008
  #94
GIOSAFAT's Avatar
Originally Posted by AznChinksta
GUSY PROBLEM BIG PROBLEM
i wired the ingnition and injection and now its not even starting, it starts and gives a nasty cranking noise and dies HELP ASAP im double checking my wiring
Ok guys nvm i fixed the problem
No spleeny, i think it has to be tuned for it to idle correctly. If you have the support tool you and fiddle around with it a little to make it idle correctly
i've some problem.
Old Jul 5, 2009
  #95
djarmyssg's Avatar
djarmyssg is an unknown quantity at this point
I know im reviving this thread from the DEAD! But i just got a couple questions.... I would like to know what Rotary settings i should use on a 2001 Civic HX d17...... I am gonna leave my Vtec completely seperate from my Emanage, but i dont wanna pitch any codes... soo if anyone knows... PLEASE hit me up!!
Jul 12, 2015 11:54 AM
