Interior Post about Interior parts, seats, consoles, etc
Drivers side lower kick panel removal
Old Apr 13, 2023
Robertlx's Avatar
Robertlx is an unknown quantity at this point
The panel that is to the left of the footrest pedal in a 2005 civic LX sedan, how to you remove or install it. Mine is loose and it seems like a needle nose pliers would twist to lock it like it does in a Corolla. But it seemed like it wouldn't turn. So my question is how do you lock it in place? It's only loose where the locking
​hole is. If I knew where to get an image of it, that would help.
Old Apr 13, 2023
BrotatoChip's Avatar
Super Moderator
Re: Drivers side lower kick panel removal
It pops into place with clips. No tools required. You may have to remove the whole thing to investigate.
Old Apr 13, 2023
Robertlx's Avatar
There's something that I felt in the hole that seems to be the locking mechanism, but I don't know if I should twist it or what
Old Apr 13, 2023
get a repair manual, they have them in auto parts stores
or get them online
https://www.civicforums.com/forums/1...hase-them.html
PS: General 7th gen section is to discuss general things about that car generation.
Most of your posts are for mechanical issues...
Moved to Mechanical issues section, interior in this case.
Old Apr 13, 2023
Robertlx's Avatar
I went back to it again to try and figure it out but there seems to be no kind of clip or snap-in for that "hole" part. It looks like it's just something to tug on and the long tube that forms the hole just rests up against the car interior frame or body
Old Apr 14, 2023
Super Moderator
This picture is looking at the back side of it. Item 12 is a push-in style clip. It slides into a notch on the end of that tube portion. It's possible someone pulled the panel off at one point and the clip separated from the panel, could still be stuck on the body.
ZeroAlligator
Interior DIY
Oct 7, 2019 08:26 AM
Kevin_646
Jun 20, 2018 11:02 PM
Kennykenny
Jul 18, 2014 04:35 PM
johneevo
Jan 25, 2011 07:43 AM
MegaHurtz
Jun 16, 2004 12:11 AM
