Stuck lower ball joints [solved]
Old Dec 25, 2021
Millsy088's Avatar
Millsy088 is an unknown quantity at this point
Hi there, so im in the process of changing my clutch and I cannot for the life of me remove the lower ball joints, I've hit control arm with a hammer very hard, I've used the separator tool which in the process has ruined the ball joints, and Ive hit the bottom of the bolt with the nut on and it has deformed the bolt and the threads, yet the ball joint hasn't moved a millimeter any help as I need to use my car in 4-5 days and I'm getting kinda frustrated
Old Dec 25, 2021
re: Stuck lower ball joints [solved]
this is the proper tool.
I had to leave it on and tighten it everyday a little bit more, until one day a loud bang indicated the ball joint finally came apart
Old Dec 26, 2021
Millsy088's Avatar
wow hahahah thats really annoying! i would have thought it wouldnt be so hard as mine arent even rusty. so ill go and buy one of them today, how tight do i do it? or do i just crank it down as hard as possible with the impact?
Old Dec 26, 2021
just be careful with an impact. Like said, it was a loud bang when it came apart. I was in the living room, doors to garage closed.
I was not in a huge hurry, I have other cars
Old Dec 26, 2021
Millsy088's Avatar
alright ill keep that in mind, but i dont have to worry too much about the ball joint as they're already absolutely destroyed from the other tool, and i do need my car in a few days!
Old Dec 26, 2021
no. the loud bang means the parts will come apart in quite a velocity. Keep fingers away
Old Dec 26, 2021
Millsy088's Avatar
ahh perfect, ill just keep my hands away and whisk it off
Old Dec 26, 2021
Colin42's Avatar
Pick up a pair of balljoints, and the balljoint press tool
Old Dec 26, 2021
Millsy088's Avatar
Yep they're already on order 😎
Old Dec 26, 2021
the ball joint removal from the knuckles is even more painful than the lower control arm...
Old Dec 26, 2021
Millsy088's Avatar
I bet they are, I'm absolutely not looking forward to this
Old Dec 26, 2021
Millsy088's Avatar
so ive put the tool on the ball joint bolt, unfortunately i couldnt get the nut back on, and i tightened it down until it slipped off also deforming the bolt, so ive put it back on and tightened it up a lot, and im going to leave it there, of course just to make things even better my ratchet is now stuck on there too
Old Dec 26, 2021
don't pee when it bangs in the middle of night
Old Dec 26, 2021
Millsy088's Avatar
Update: finally got them removed, after a lot of trial and error i decided to remove the boot from the ball joint with a pair of nippers then i turned the wheel to full lock and was then able to push the removal tool much further onto the bolt at the bottom, and then after ditching the ratchet and moving over to a 30 inch breaker bar i was finally able to crack both of them free!
Old Dec 26, 2021
did you pee? glad it is out!
Old Dec 27, 2021
Millsy088's Avatar
Hahaha nearly! It was very loud! But I can finally continue with the rest of the job
Old Dec 27, 2021
7thgenlegend's Avatar
7thgenlegend is an unknown quantity at this point
Thanks for discussing this guys, I need to replace both ball joints, LCA bushings and tie rod ends on my 213k mile 04 civic. Any advice on a tool to separate tie rod from knuckle?
Old Dec 27, 2021
Millsy088's Avatar
I can't offer too much advice, but the tool that I was told to get is also apparently able to remove tie rod ends, and I would think a pickle fork might work too, although like I said I don't have any experience with the tie rods
Old Dec 27, 2021
Colin42's Avatar
Just smack the knuckle with a hammer, shouldn't be in there too bad. Heat and penetrating fluid helps
Old Dec 30, 2021
bachands's Avatar
bachands is just really nicebachands is just really nicebachands is just really nicebachands is just really nice
Re: Stuck lower ball joints [solved]
If you work on steering/suspension often enough, it pays to get an entire front end service kit. See link below for a reputable brand:
https://www.homedepot.com/p/Powerbui...203120753-_-N&
The one I have I got on eBay, but it works well. I am always able to get the joint out. They can also be used to remove inner races from wheel hubs and removing wiper arms from their splined shafts.
maverickfhs
35
May 21, 2017 06:24 PM
s7khan
Transmission
Mar 6, 2013 10:27 PM
woohoo321
Jul 14, 2012 11:18 PM
Demonicus666
Jun 8, 2006 10:31 AM
