2002 power steering pump leakage fixable?
Old Mar 21, 2021
niemand's Avatar
niemand is an unknown quantity at this point
I just discovered my 2002 Civic LX has been leaking power steering fluid. I see possible issue with the o-ring (91345-RDA-A01) and suction hose (53731-S5D-A01), but it looks like there's more. Is it feasible or possible to fix this myself? If so, I'd need part #s. Or does the entire pump need to be replaced?
What parts are needed to fix this leak?
I am guessing 25 and 24 would fix the seepage, but I can't find the part #s for those. I know only that 20 is 91345-RDA-A01. And what is part #3 called?
Suction hose end below the reservoir also looks leaky. Is this a problem with the clamp or the hose? Could this have been caused by me when replacing the headlight bulb the previous day?
Thanks.
Old Mar 21, 2021
bachands's Avatar
bachands is just really nicebachands is just really nicebachands is just really nicebachands is just really nice
Re: 2002 power steering pump leakage fixable?
I read about those o-rings going bad too. It looks like you already have the P/Ns. Ebay sells them as a repair kit.
But will it fix the leaking? Hard to tell. It may be leaking from the body itself, which would require replacement of the pump. Great video of how to do this on YT by 1AAuto.
I would try cleaning the area as best you can to see if you can pinpoint the leak. Buy the o-rings first, replace them, and see if it fixes the problem. I would also try replacing that pump-to-reservoir hose also. It doesn't cost much.
When you refill the PS fluid, be sure to use genuine Honda fluid or at least fluid specifically for Honda (I used Wagner DOT 3&4 for Honda/Acura).
You really just need a 12mm socket (and maybe a 10mm also), a ratchet, extension, and a pliers. The one bolt underneath the pulley is a pain to get to, but do-able.
Old Mar 22, 2021
niemand's Avatar
I don't have the part #s to the o-rings ref'd by 21, 24, & 25 in the diagram:
The o-ring ref'd by 23 above (part # 91347-PLA-003) isn't a problem. The o-ring ref'd by 16 (part # 91370-SV4-000) below also seems fine:
16 (part # 91370-SV4-000) doesn't appear to be leaking.
I see a video demonstrating rebuilding the pump with new o-rings, but I don't want DuraLast/O'Reilly parts:
Old Mar 22, 2021
niemand's Avatar
Found o-ring part #s:
20: O-Ring (13.0X1.9) - Honda (91345-RDA-A01) (orange, end of suction hose at joint inlet 56123-PLA-003),
21: O-Ring (23.8X2.4) - Honda (91346-PLA-003)
22: O-Ring (16.7X1.8) - Honda (91347-PAA-A01)
23: O-Ring (12.7X1.8) - Honda (91347-PLA-003) under the 19 mm pressure regulator bolt
24: O-Ring (51.0X2.4) - Honda (91348-P2A-003)
25: Seal, Pump Cover - Honda (91349-PLA-003)
Old Mar 22, 2021
bachands's Avatar
Based on the location of the leakage, I would replace the pump itself. I would take my chances with a reman unit because I don't think I have the skills to rebuild it. Either way you must remove the pump and refill with fluid.
But hey, if you want a little project and a few o-rings costs way less than the pump, then have at it. Take your time and take pictures (or video) as you go so can remember what goes where.
Old Mar 22, 2021
niemand's Avatar
I added the Honda power steering fluid this morning to the upper level. Will first see how much it loses over the next 1000 miles or so.
MetalAttack 666
Suspension
Dec 2, 2021 06:35 AM
teezyyoxo
May 4, 2017 10:36 PM
Sailorman3
Nov 10, 2013 11:27 AM
94civicd16z6
18
Jul 26, 2012 03:09 PM
cobrapimp
Bolt-on Engine Performance
Mar 5, 2003 02:08 AM
