2004 Civic - any need for lubrication?
Old Jan 4, 2021
roman45's Avatar
roman45 is an unknown quantity at this point
I realize most cars no longer need lube jobs, but I have come into possession of a 2004 Honda Civic and I'm going to take it in for maintenance. So my question is, is there anything - steering, suspension, drivetrain, etc - that needs to be lubed?
Old Jan 4, 2021
CraigW's Avatar
Re: 2004 Civic - any need for lubrication?
My question would be the status of the timing belt.... on a 7th gen, personally.
Old Jan 4, 2021
maxeymum's Avatar
maxeymum is a jewel in the roughmaxeymum is a jewel in the roughmaxeymum is a jewel in the rough
Yeah, like CraigW says, timing belt is crucial, along with valve adjustment if it's never been done. Also change all fluids if you don't know last time they were done.
Old Jan 4, 2021
Also check coolant levels in radiator and reservoir.
if radiator is lacking and reservoir is full, potential headgasket breach (It's easier to do timing belt/water pump and gasket at once)
https://www.civicforums.com/forums/3...r-blowing-cold
if levels ok, *should be OK*
read here:
https://www.civicforums.com/forums/1...gen-civic.html
Old Jan 4, 2021
Colin42's Avatar
If any suspension parts have been replaced with aftermarket parts there may be grease points
Old Jan 4, 2021
roman45's Avatar
Thanks guys for all the tips/help!
trev0006
Dec 20, 2006 04:13 PM
CvC-v01
Jan 30, 2004 10:12 PM
Jas88
Jul 24, 2003 07:27 PM
Grey
North East
Apr 17, 2003 10:13 AM
