Front End Problems/Noise
Old Aug 22, 2013
Car Slave's Avatar
Car Slave is an unknown quantity at this point
Question Front End Problems/Noise
Had a number of issues with all kinds of different noises. Have been eliminating one at a time.
Car 2003 Civic EX w/ 175,000 miles - bought car w/ 151K
Work to date:
*4 Wheel alignment
*New tires summer tires on front - balanced - 7000 miles on tires
Tires were new on rear when car was purchased
*New Control arms & ball joints
*New ready mount struts both sides
*New brake rotors and pads
* Have check wheel bearings - no movement - no vibration or noise - no evidence of seal leakage.
* Tie rod ball joints are tight.
* Did not replace sway bar links because there was no play or looseness.
* Have not had the front end re-align since replacement of struts & control arms - That will be done next week.
Still have vibration in front that can be felt in steering wheel at speeds above 50 MPH.
At low speed with windows open and listening closely can hear a barely audible clunk or thud when going over a certain kind of road imperfection.
Where do I look next? What have I missed?
Old Aug 22, 2013
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Re: Front End Problems/Noise
Come back after the alignment and see if anything changes.
Old Aug 22, 2013
BlueEM2's Avatar
Whachya lookin at?
First thing on his list is 4 wheel alignment. Good luck, I've been chasing a clunk on mine for about a year and I've replaced every suspension component that exists. Seems like youve done about the same.
Old Aug 22, 2013
got2run5's Avatar
I mean after this one since he messed with it.
edspyhill09
Jun 12, 2016 02:45 PM
Lopes101
Jun 7, 2015 08:04 PM
chuffsy
May 15, 2015 12:50 PM
pheaton
May 4, 2015 08:26 PM
GH04si
Apr 15, 2015 08:13 PM
