Brakes Post Your questions about brakes here!
2001 civic with ABS brake proportioning valve reset
Old Nov 23, 2024
Charlesabrn's Avatar
Charlesabrn is an unknown quantity at this point
My 2001 civic had a sticky front caliper so replaced both calipers and in the process also the master cylinder. In the following brake bleeding process, rear brakes didn’t get any fluid. I figured the proportioning valve kicked in to stop fluid to the rear brakes. I tried many tricks I learned from YouTube to try to reset the proportioning valve to no avail. Now I think I have the following options:
1. remove the proportioning valve and try to reset it (is there any way to do it)then reinstall it.
2. Go to a junk yard to remove it from a donor car the replace the one on my car
3. Go to a mechanic to reset the valve.
What do you guys think?
Old Nov 23, 2024
Re: 2001 civic with ABS brake proportioning valve reset
I have to add that I did whole brake system bleeding 3 months ago with no issues. The fluid to rear brakes were cut off after recent calipers and master cylinder replacement.
lohughes
Nov 12, 2014 07:35 PM
Graeme.Crawley
Jun 4, 2011 12:18 AM
2ndGen
Feb 16, 2010 06:16 PM
jweb42055
Jan 28, 2009 10:38 AM
streetglower
Jun 9, 2005 08:06 PM
