Replaced broken pedal pad
I had a broken pedal pad. I removed and unplugged the sensor then replace the pedal pad reinstall the sensor the next time I drove the car. The left front caliper locked up after about 5 minutes of driving . Released after about 40 minutes of sitting but continued to lock up shortly after driving. Replaced left front caliper then the problem switched to right front caliper. Replaced right front caliper still have the same problem got any suggestions
Re: Replaced broken pedal pad
Recheck work done, retrace steps.
decided to google, sorry for asking, was a honest question
"What does a brake pedal stopper do?
The brake pedal stop pad, or brake light stop pad, is a small stopper that pushes in the brake light switch to turn off your brake lights when the brake pedal is not depressed. It is found attached to the brake pedal arm under the dashboard. It is usually made of plastic and can wear out over time."
https://www.autozone.com/interior/brake-pedal-stop-pad
Ken Thresher
May 21, 2020 10:42 PM
