Brakes Post Your questions about brakes here!
Spongy brakes [solved]
Old May 5, 2023
Sitnikoff_s's Avatar
Sitnikoff_s is an unknown quantity at this point
Originally Posted by Frostysinco
well I put the drum back on snug and put all the tires back on and I’m left with a spongy bake
hi! Do you fix your problem? Cause I have the same problem, but drums are new
Old May 5, 2023
Colin42's Avatar
re: Spongy brakes [solved]
What else did you do besides change the drums? Why did you change the drums?
Old May 5, 2023
I've çhanged front brake disks, pads, caliperes and rear drums, shoes, everyones spring including adjustment parts, wheel cylinders. Everything is new.
I bought car and decide spend more money for my sefty...
P.s. I bleed brakes five times based on honda manual ( front drivers, front passenger, rear passenger, rear drivers)
Old May 5, 2023
do you have ABS?
Did you drain fluid by chance? ABS need to be bench bled if air got in.
Old May 5, 2023
Originally Posted by sdaidoji
do you have ABS?
no abs. 2003 honda civic lx
Old May 5, 2023
are you losing fluid from tank?
Pipes?
Have someone else do the bleeding? Many people find out their method was faulty somewhere.
Old May 5, 2023
Pipes?
Checked tubes - dry. the liquid level does not change. I bled the brakes with an assistant. I think the problem is in the master cylinder, because when the engine starts, the pedal almost goes to the floor ...
Also I checked hose from brake booster, and i think he works
Old May 5, 2023
Colin42's Avatar
Could be, it's 20 years old
Old May 12, 2023
i solved this problem. maybe someone will help. I mixed up the right and left front caliper. I understood this due to the fact that the bleeder was directed downwards, and not upwards😅
Old May 15, 2023
BrotatoChip's Avatar
Super Moderator
Re: Spongy brakes [solved]
Glad you figured it out.
Frostysinco
Brakes
19
Dec 7, 2022 07:42 AM
BrotatoChip
Brakes
May 10, 2021 06:45 AM
felicianojerome
Brakes
Nov 11, 2020 06:52 AM
got2run5
May 16, 2017 06:41 PM
EM2Civic
Oct 13, 2004 04:12 AM
