Brakes Post Your questions about brakes here!
leaking caliper help
Old Apr 3, 2021
hiac's Avatar
hiac is an unknown quantity at this point
Hi,
I changed caliper two years ago. it works fine until 3 months ago. it start to leak even if I park the car. I plan to replace the caliper, but I notice the oily section on the rubber line (red mark). is it a sign maybe the line itself has some issue?
Thank you very much!
Old Apr 3, 2021
Colin42's Avatar
Re: leaking caliper help
That whole caliper looks damp, hose everything off with some brake cleaner and see if you can pinpoint the source of the leak
Old Apr 3, 2021
hiac's Avatar
Thank you for your reply. yes, it is damp. I didn't drive it in last 3 weeks, and by measure the brake fluid level, I can tell it's constantly leak.
is it how it should be done: remove caliper bolt, remove break pad, clean it up? Do I need to push the pedal couple of time maybe it will show leakage?
Thank you again!
Old Apr 3, 2021
Colin42's Avatar
Leave everything assembled for now. Hose it down with brake cleaner. Let it dry and then pump the pedal a couple times. Have a look and see if you can tell where it's leaking from.
Old Apr 3, 2021
hiac's Avatar
Thank you very much Colin42, as always!
Old Apr 3, 2021
Colin42's Avatar
No worries, let us know what you find
Old Apr 5, 2021
BrotatoChip's Avatar
Super Moderator
2 years old and the caliper looks like that? In the future I would recommend going to RockAuto (or similar) and finding coated calipers to prevent rust.
Old Apr 5, 2021
Colin42's Avatar
2 years old and the caliper looks like that?.
welcome to Canada
Old Apr 5, 2021
Super Moderator
You don't need salt to get that rusty, just un-coated parts
old97civic
Nov 14, 2015 05:42 PM
michele7871
Nov 20, 2014 08:47 PM
em2maxamillian
Brakes
Oct 1, 2011 01:25 PM
Doon
Mar 16, 2011 08:24 PM
streetglower
Aug 21, 2004 05:35 PM
