Brake Pedal 'Whistle'
Old Mar 12, 2011
Doon's Avatar
Doon is an unknown quantity at this point
Here's my situation; My brakes or brake pedal makes a 'high pitched' sound when I release it after having had it depressed for any amount of time. It almost sounds like a whistle or a long squeaky sound. I've listened, and it sounds loudest inside the cabin. In an effort to alleviate the issue I recently had the dealer do a fluid service, and I replaced the pads & rotors. Nothing worked. It doesn't seem to bad when the car is cold, but after some use the noise appears.
Could it be that something in the brake pedal linkage needs to be lubricated, or is it a symptom of something else, like air in the master cylinder?
Thanks-in-advance for your opinions!
Old Mar 12, 2011
Re: Brake Pedal 'Whistle'
prolly coming from the pedal then? put a cloth over the brake pedal and spray some silicone lube up where the pivot point is. if its coming from the outside, it could be the e-brake cable squeaking.
Old Mar 16, 2011
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
Not to alarm you, but your brake booster might have a leak. Just a possibility.
But of course it's doubtful you would have a leak on the casing of the booster, it would be a leak with the diaphragm.
Low_Lupe
Aug 17, 2015 10:57 AM
JetsterDajet
Aug 15, 2015 08:07 AM
honda.lioness
Aug 6, 2015 11:58 AM
wootah88
Jul 21, 2015 10:22 AM
Causemo
Jul 5, 2015 06:42 AM
