Brakes Post Your questions about brakes here!
it possible the brakes could briefly malfunction then back to normal
Old Nov 13, 2019
hiac's Avatar
hiac is an unknown quantity at this point
we get some snow and ice on the local road.
I drove my honda civc 02, and try to stop at the right light (this stop is about 5 min drive from my garage), and feel brake stop working even though I push all the way to floor. But luckily it finally stop.
after that point, brake is fine, and I can drive on highway without issue.
I suspect there might be some ice on the local road (pretty busy road), I am not sure.
But is it possible the break could briefly malfunction then back to normal? I need to troubleshoot a little bit, but what I should look for?
Thank you!
Old Nov 13, 2019
Slumpertcivic's Avatar
Re: it possible the break could briefly malfunction then back to normal
If you ever can push the pedal all the way down, stop driving the car and get it to a repair shop. To drive said car could be life threating.
Pumping the brake pedal to “restore” braking force is not a fix for the problem.
Old Nov 13, 2019
mac25's Avatar
Dr Krieger of Modification
If it was pulsing on and off, fast, in rhythm, that's normal ABS functionality.
Old Nov 14, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: it possible the brakes could briefly malfunction then back to normal
All the way to floor? Recommend you get the brake system checked ASAP. Could be a faulty brake booster, master cylinder or something else. Was work on the brake system done recently?
Old May 4, 2021
jbbbk89's Avatar
jbbbk89 is an unknown quantity at this point
we had teh same problem. once we stopped to car by hitting the curb on the sidewalk. but second time it happened we hit the car in front of and ourt car is totaled.
Old May 4, 2021
BrotatoChip's Avatar
Super Moderator
This is for a 2002 Civic, not a 10th gen. It's going to be different.
They also mention snow and ice. This could have been ABS kicking in to prevent lockup on the snow/ice making it feel like they couldn't stop.
RyanHostetler
Dec 5, 2016 03:56 AM
Bricoleur
Oct 6, 2015 09:50 PM
lazypunk502
Mar 25, 2013 08:29 PM
nyyanks81
May 12, 2005 01:45 PM
NBPD17A2
Dec 27, 2002 02:43 PM
