Idle Issues If you have idle issues, post here!
Hanging Idle 2001 EP2
Old Jun 1, 2022
Amity800's Avatar
Amity800 is an unknown quantity at this point
Okay here's the story guys I bought an EP2 manual (D16V1) the engine is the same as the D17.
​​​​​​When I bought the car the idle was fine but sometimes it would dip down to 600 and the car would shake.
I got a throttle body from a friend that was free with the IACV on it and all other sensors.
I replaced mine throttle body and found out the friends one was crapped out and returned my original one.
After that my idle would stick at 1500-2000 whenever the car was moving or I given it any throttle input (neutral downhill or creeping). So basically I give it any throttle input it would surge to 1500-2000 stat there and return to 900. If the car was just rolling in neutral it would also surge by itself to 1500-2000 and come back as soon as I stopped to 800-900.
I tried a third different throttle body and IACV that was confirmed working and it's the same exact issue.
I also sprayed all the vacuum lines with brake cleaner and couldn't locate any vacuum leaks.
The weird thing is after I returned my OG throttle body and it's senors I went on a trip that was 300 miles constant highway at a constant rpm and speed. When I arrived to my destination my car idled fine and there was no issues. On my way back i ran out of LPG (liquid petroleum gas) and was driving on gas I stopped to topped up, shut off my car and turned it back up again and a check engine appeared and the car was idling like **** again. The check engine is gone and was LPG related.
My car has this idle problem running on gas and LPG.
Any suggestions, ideas?
Do I need to do idle relearn maybe?
Creager
Dec 28, 2013 09:29 PM
rileyb22
18
Mar 21, 2012 11:31 PM
civcspool
16
Jan 30, 2009 10:34 AM
Hwoody77
Engine Swaps
Jun 26, 2005 10:37 AM
Pharoh
Aug 15, 2004 02:03 AM
