Sporatic Idle + Sticky throttle = ?
Old Jun 26, 2005
Hwoody77's Avatar
Hwoody77 can only hope to improve
Hey everyone, just wanted to see if anyone can figure this out. I have a turboed 02 Civic, now even before I put in the turbo I started having this problem, where the car will rev itself up and down for a few times up until about 2500 RPM, then when I give it gas or come to a stop the idle stays sticky unless I blip the gas in which case it'll stop or start reving up and down...anyone have any idea what the problem is?
Old Jun 26, 2005
dragoon's Avatar
check your vacuum lines
Old Jun 26, 2005
could be a number of things
throttle cable is too tight (if you tightened it)
throttle body is dirty (get some tb cleaner and clean around the valve plate and intake)
idle air control valve is broken (prolly not this unless the car is stalling out)
bad tps sensor (it might be this if you have fluctuating rpms)
try the easy stuff first, then its time for a new throttle body.
Old Jun 26, 2005
Hwoody77's Avatar
Vacuum leak...thanks guys!
GritzNGravy
Aug 19, 2015 03:03 AM
Martinez8o5
Jul 31, 2015 10:58 PM
Dani1993
Jul 24, 2015 09:02 AM
ezone
HIDs and Retrofitting
Jul 4, 2015 12:44 PM
