changing the ATF fluid...
Old 21 Hours Ago
awesome civic's Avatar
awesome civic is an unknown quantity at this point
Hey everyone...gonna have my transmission fluid on my 2003 Civic EX coupe changed..it's an automatic.....the dealer wants over 10.00/qt for the ATF fluid...I'll pay it if necessary..but does anyone advocate for aftermarket ATF fluid that is just as good but less expensive?? I will only use something that is equivalent to OEM...and only if it's considerably less money...
Thanks everyone...
Old 8 Hours Ago
crajnai's Avatar
7th Gen Victim
crajnai has a spectacular aura aboutcrajnai has a spectacular aura about
Re: changing the ATF fluid...
When I bought my 2003 EX it had some aftermarket fluid in it. Shifted terribly. This forum suggested genuine ATF. Had to run it 400 miles and flush again before it ran properly. I was ready to give up or start swapping solenoids but the double change solved the issues. 30k later I switched it again with ATF. Another 15k and it’s still shifting fine. Topped it off maybe once.
TLDR: No.
It only takes like three quarts if I recall. What you gonna save, maybe five bucks? This is one genuine part I would not consider an alternative to. Happened to me in a Kia I had too, transmissions are temperamental enough without substitutes.
Jordan.Sleeper
Transmission
Sep 9, 2023 09:42 AM
Kennykenny
Jul 25, 2016 07:12 AM
Chuck K
Mar 16, 2016 08:26 PM
torontob
19
Jan 11, 2011 01:36 PM
the-troglodytes
Jun 17, 2007 02:42 AM
