Rattle in park and reverse
Old Jan 1, 2026
Jerry.Jobe1980's Avatar
05 Honda Civic VP 1.7L
Jerry.Jobe1980 is an unknown quantity at this point
I'm new to this community, and look forward to any input. I recently replaced my rear main seal which required dropping the transmission. I put everything back together (I swapped the transmission before without issue). Now when the car starts, in park, and in reverse it makes this rattle. In drive or neutral, no issues at all. I'm not sure if it's something with the mounts, or if the torque converter didn't seat correctly.
Any thoughts?
Thanks
JJ
Old Jan 1, 2026
FRSam's Avatar
Click Here
Re: Rattle in park and reverse
Might need a video to confirm, but I feel like anything mount-related would happen regardless of gear. From the sounds of it, the transmission needs to come out again.
Old Jan 2, 2026
Car shifts and drives smoothly. I looked closer at it today, and the motor moves significantly when it's turned on and shifting through to drive. I really feel it's the mounts went bad. To my knowledge, they've never been replaced. I'm waiting for a mechanic friend of mine to take a look to confirm.
Old Jan 3, 2026
FRSam's Avatar
Click Here
Have someone rev the car in neutral. That will tell you.
Old Jan 5, 2026
It was definitely the motor mounts. Replaced three of the four. No more sounds. I'll do the backside one this weekend.
Old Jan 6, 2026
FRSam's Avatar
Click Here
Glad you figured it out.
AY15
Transmission
Feb 5, 2023 03:58 PM
raaxaa
Transmission
29
Sep 18, 2022 01:48 PM
01Prelude
Oct 13, 2013 09:09 PM
retro
Sep 7, 2005 03:01 PM
