Shifter stuck in park
Old Mar 9, 2025
Tylerf150's Avatar
Tylerf150 is an unknown quantity at this point
The other day, the shifter on my 2005 Civic was stuck in the park. I manually released it and got it home. Now, I've been trying to resolve the issue, and I'm stuck.
1) I checked the #7 fuse. It was good, and the horn works
2) I replaced the brake sensor with one from the wreckers, and it didn't help.
3) I also tried replacing the shifter solenoid still, nothing
When i turn the key on i have no brake lights, the shifter is still locked , No click from the center console.
But last night I plugged a 15 amp fuse in the female receiver for the brake sensor to see if I could jumper the circuit. At first nothing happened, then 30 min later, the lights came on while the keys were not in the ignition. I was able to start the car and the shifter released. But the brake lights would not come off.
Any ideas ?
Old Mar 11, 2025
Colin42's Avatar
Re: Shifter stuck in park
Brake switch might be bad if the lights are staying on
semora
Transmission
28
May 13, 2022 05:38 PM
Un4givenshadow
May 31, 2012 07:23 PM
rsmacca58
Jan 7, 2012 12:56 PM
PANOZ59
Jan 11, 2008 04:04 PM
