Transmission??? Or something else
Old Mar 7, 2023
MoneyMayo215's Avatar
MoneyMayo215 is an unknown quantity at this point
So I have an 2003 Honda Civic EX 4DR Auto BMXA trans….so I had the flashing D and a DTC P1753 I removed cleaned and put back the 3 solenoids on the trans…the P1753 went away….but the issue I’m having now is I turn the car on and if I let it warm up and put it in rev or drive it won’t take it at all….like you don’t feel it go into gear….if you turn it on and quickly shift to rev or drive it will take it and then if you stop and try to give it gas it won’t move than when you switch to rev from drive or vice versa it won’t take any gear…..what could that be??? Or do you guys think the trans needs help???? Lol
Old Mar 7, 2023
Colin42's Avatar
Re: Transmission??? Or something else
Trans is most likely shot. Try doing 3 drain and fills but it pro probably wont help.
Old Mar 9, 2023
Does this car have a transmission pan that I can take down and change the filter????
Old Mar 9, 2023
Colin42's Avatar
Nope you have to pretty much dismantle the entire trans
Old Mar 9, 2023
so you can’t change the filter??? Why Honda why????
Old Mar 9, 2023
BrotatoChip's Avatar
Super Moderator
You can change the filter. It's just located inside the transmission requiring a teardown to get to.
Old Mar 10, 2023
I feel like ima have to change the transmission anyway so why bother right….
Old Mar 10, 2023
Super Moderator
A filter change may not fix it. Probably best to replace or rebuild.
lynley
Transmission
Aug 2, 2022 08:04 PM
kvfertig
Transmission
Jul 7, 2021 05:43 PM
mattandchris
Sep 12, 2012 12:26 AM
Curiouz_G
Sep 28, 2006 06:36 PM
