Car running slugish
Old Nov 15, 2021
Frostysinco's Avatar
Frostysinco is an unknown quantity at this point
Car running slugish
So I finally thought I fixed it and drove it to another city just to have the codes pop back up on me . And the car going sluggish and the heat stopped working as well
Old Nov 15, 2021
Re: Car running slugish
what codes?
Old Nov 15, 2021
Originally Posted by sdaidoji
what codes?
solenoid code and one po118
Old Nov 16, 2021
BrotatoChip's Avatar
Super Moderator
Low on coolant? Bad head gasket?
Old Nov 16, 2021
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Second the head gasket breached - common issue on these engines.
Old Nov 16, 2021
it was low on coolant and I added some but still it didn’t fix anything
head gasket was recently changed
Old Nov 16, 2021
Super Moderator
That doesn't mean it's ok. The heat stopped working which could mean you're low on coolant. Start with checking coolant level.
Old Nov 16, 2021
I added coolant to it but when I got back to my car the coolant reservoir cap was missing could that have something to do with the heating ?
update
I took the coolant out the reservoir since it was over full and. Now the heat it back on just doesn’t blow hard
Old Nov 16, 2021
Super Moderator
Watch those coolant levels, probably a good idea to burp the system too. If the reservoir keeps gaining coolant you'll be getting another head gasket replacement soon.
Old Nov 16, 2021
Colin42's Avatar
Head gasket or you didn't bleed the coolant properly
Old Nov 16, 2021
okay update so I got the car running again and the heat going but I keep getting a coolant sensor code and the car goes sluggish around the 30 mph mark otherwise it’s running fine and it doesn’t happen all the time
Old Nov 17, 2021
FRSam's Avatar
Click Here
What brand sensor did you use? These cars are very select with what works.
Also, with the head gasket, did a shop replace it or did you do it yourself?
Old Nov 17, 2021
Super Moderator
Also, are the coolant temp sensors plugged in? Passenger side of engine, towards the front, very close to where the top radiator hose meets the engine. Both have to be unplugged when replacing the head gasket.
Old Nov 17, 2021
NDNV's Avatar
"I added coolant to it but when I got back to my car the coolant reservoir cap was missing could that have something to do with the heating ?
update
I took the coolant out the reservoir since it was over full and. Now the heat it back on just doesn’t blow hard"
More symptoms of a breached head gasket so might be your problem.
Old Nov 17, 2021
I used a cheap eBay replacement
Old Nov 17, 2021
I did the head gasket on my own with the sand paper little by little
Old Nov 17, 2021
FRSam's Avatar
Click Here
I would say that's your problem. The mating surface was most likely uneven (eye test is not a proper way of checking) and the sensor isn't working properly.
Old Nov 17, 2021
Colin42's Avatar
Wrong and wrong
Old Nov 17, 2021
I check it with the gauge and ruler lol I didn’t just eye ball it
Old Nov 17, 2021
FRSam's Avatar
Click Here
Yeah, I still don't think it's completely flat. Sandpaper isn't exactly a precise tool.
Old Nov 18, 2021
Super Moderator
I agree with both of them but you should still test. You can try putting in an OEM sensor, even a used one from the junkyard. Then properly burp the coolant system and get fluid levels correct. If the reservoir keeps gaining while the radiator is losing it's almost certainly the head gasket.
Old Nov 24, 2021
I’m back and this time it’s throw a p2770 code and sluggish the previous code was resolved sort of because I found out the cap was falling off to the coolant reservoir causing coolant to evaporate. This time it’s saying the solenoid is no working when I replaced it with a new one and had the car working fine for a while there .
Old Nov 29, 2021
Super Moderator
Coolant evaporates at an incredibly slow rate, that's not your issue. That cap is vented anyways (not sealed) so you could leave it off and not hurt anything.
Old Dec 1, 2021
yeah it’s just p2770 code It d light. Blinks and car is sluggish 🤷
Old Dec 2, 2021
NDNV's Avatar
Powertrain issue then if D light blinking. Check your ATF condition and level. Maybe a bad connection at a transmission harness?
ReD2k1
20
Jul 17, 2023 06:46 AM
91LXdriver
May 13, 2016 08:41 PM
Zed
83
Mar 18, 2015 10:21 AM
Spazzyt5
Jan 26, 2013 09:26 PM
