Help with 05 civic auto transmission issues and install
Old Aug 13, 2021
msv96's Avatar
msv96 is an unknown quantity at this point
So long story short I had to replace my transmission on my 05 civic. I didn't put anything in neutral and I yanked out the shifter cable.. I went and bought a used transmission shifter cable and shifter. The problem that I'm having now is I can't line anything up. I try to put the transmission in neutral by hand than the shifter and cable as well as the range sensor but when I turn on the civic and shift it the shifter on the dash goes all over the place it doesn't mark it right. I'm stuck and need help. What should I do?
Old Aug 13, 2021
Colin42's Avatar
Re: Help with 05 civic auto transmission issues and install
Did you buy a JDM trans or a normal one?
Put the trans in neutral and the shifter in neutral, there's adjustment in the cable to get everything lined up
Old Aug 13, 2021
msv96's Avatar
from the junkyard oem. Trans is good though. How though I've tried and still nothing
Old Aug 14, 2021
msv96's Avatar
also how many clicks for it to be in neutral
Old Aug 14, 2021
Colin42's Avatar
Park, reverse, neutral...
Old Aug 14, 2021
msv96's Avatar
I've done that. But for whatever reason it's still off. Could I have a bad cable?
Old Aug 14, 2021
Colin42's Avatar
Have you tried adjusting the cable? Are you sure it's routed properly?
Old Aug 14, 2021
msv96's Avatar
Yes it routed properly. Adjusting the cable how?
Old Aug 14, 2021
Colin42's Avatar
You should be able to make adjustments on the interior end
Old Aug 15, 2021
msv96's Avatar
just pulling the cable?
Old Aug 15, 2021
Colin42's Avatar
....... no.
The end of the cable is adjustable.
Old Aug 16, 2021
msv96's Avatar
....... no.
how do you adjust it? Do you turn something or pull something?
Old Aug 16, 2021
Colin42's Avatar
Post a picture of the interior cable end
Old Aug 16, 2021
have you removed the center console to see how things are under there?
Old Aug 17, 2021
msv96's Avatar
Old Aug 17, 2021
Colin42's Avatar
That silver part that's bolted to the shifter should be threaded so you can adjust the length of the cable
Old Aug 17, 2021
msv96's Avatar
it's not threaded I can pull it in and out. Is that what you mean?
Old Aug 17, 2021
Colin42's Avatar
Go download the service manual on the last page here:
https://www.civicforums.com/forums/1...ispreloading=1
Starting on page 1115 it has all the information on how to remove, install, and adjust the cable. It's a little more involved than what I was thinking.
Hardcoresteve
Part and Product Reviews
Aug 25, 2011 02:01 AM
ender159
Aug 9, 2005 08:57 AM
01civi
Jun 13, 2005 01:56 PM
runner1738
Jul 26, 2003 07:36 PM
blouisgod
Mar 17, 2002 06:17 PM
