Can I change clutch fork without removing transmission
Old Apr 12, 2021
Cdubois1988's Avatar
Cdubois1988 is an unknown quantity at this point
So as I was leaving work on Friday my clutch pedal got extremely hard and wouldn't disengage my clutch. As I was checking everything out I found that my clutch fork pivot ball has made its way through the fork. I was able to get the fork pried back off of the pivot ball, but with the hole now in the fork it will obviously not work anymore the way it is. I removed the spring that holds the fork to the pivot ball and the fork is nice and loose now but I can't seem to dislodge it from the throw out bearing. Is it possible to remove this clutch fork without pulling the transmission? If so, how?
Old Apr 12, 2021
BrotatoChip's Avatar
Super Moderator
Re: Can I change clutch fork without removing transmission
The clutch fork will slide out of the throwout bearing but it's not able to clear the pivot ball and the clutch case. Unfortunately, you will need to at least partially separate the transmission from the engine.
At least that was my experience the one time I tried to pull it out without removing the transmission.
Old Apr 12, 2021
Colin42's Avatar
Gotta pull the trans
surge6644
Jun 26, 2014 04:39 AM
number4t1
May 21, 2009 02:30 PM
KalliGarri
Apr 5, 2004 10:35 PM
CrewChief
Bolt-on Engine Performance
16
Dec 16, 2003 01:02 PM
ImportRacer2123
Nov 11, 2003 12:08 PM
