Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
clutch fork/ throw out beating troubles
Old Jun 26, 2014
surge6644's Avatar
surge6644 is an unknown quantity at this point
Had a Frankenstein but did away with b18 block and replaced with b16 block.I kept the fly wheel and so far plan to continue using an Ls transmission.I put in new stage 3 clutch but the clutch fork is not getting the bearing as far as it needs to be to engage clutch.as if to say the clutch fork has 90% play and engages on its last 10. Seems like it'd be easy to just add a couple washers under the pivot ball to gain leverage maybe even macgyver the clutch fork with a little welding. The clutch kit bolts on perfectly but that bearing just isn't going far enough...help?
mjdiaz89
Jun 21, 2016 09:26 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
06Si_Girl
Jul 12, 2015 12:08 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
