New ACT Clutch info
Old Dec 15, 2003
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
New ACT Clutch info
I just swapt out my clutch and flywheel with an ACT 270lb street clutch and 11lb flywheel. The whole process wasn't that bad. Here is the catch. Because the clutch is 100% stronger than stock it take all the length of the clutch pedel to disengauge. I bled all the air out of it and that is how it is. The clutch catches about a half an inch from on the floor. The only way I can think to change it so it disengauges earlier is to put thicker fluid in it. How it is right now is not bad because I usually push the clutch all the way to the floor to shift any way. But in traffic if you let it slip just a little bit it catches and you move. The engaugement is not that rough but you can feel a differance. Just thought you might want to know. Hope this helps somebody. Oh and I upgraded it for my turdo kit I will put on next weekend. Ran out of time last one.
Old Dec 15, 2003
ASWZero's Avatar
ASWZero is an unknown quantity at this point
lucky man, nice avatar!!!
On the quest for more power and a car that can drift...
give me time, give me time.
Old Dec 15, 2003
C2i0v0i1C's Avatar
SuperMODrizd
it should loosen up over time, mine did, i think u can adjust it too
Old Dec 15, 2003
CrewChief's Avatar
I like the stiffness but it is how far you have to push the clutch down to get it to disengauge. Is yours like that as well. Oh and do you know how to adjust it.
Old Dec 15, 2003
civic01vtec's Avatar
how long did it take u to do the install ?
Old Dec 15, 2003
CrewChief's Avatar
I had two people and it took us from 1pm to 6pm sat and from 10am to 4pm sun. 10 hours total. Not too bad seeing as I have never done a FWD car befor and my Friend has never done one with the engine in the car.
Old Dec 15, 2003
^^^.....ok, so u just had to drop the tranny then
i have changed clutches in dumptrucks and stuff, but there is alot more room to work around in.....lol
i can do them in 2 - 3 hrs
Old Dec 15, 2003
this calls for a DIY !!!!!!!!
Old Dec 15, 2003
CrewChief's Avatar
The big problem is you can not get the tranny out of the car without removing the sub frame or pulling the engine. We just pushed to the side and worked around it. Not muck hand room though.
Old Dec 15, 2003
CrewChief's Avatar
I'll work on writing one out and post it later. At work at the moment.
Old Dec 15, 2003
ImportRacer2123's Avatar
K20 Member
Thats why when I go and do my tranny swap im going to change my clutch as well i just need to find the perfect one to meet my power needs. Power will be 75 shot+ PnP Head. anyone have any suggestions?
Old Dec 15, 2003
Elite's Avatar
Elite is an unknown quantity at this point
i have 6 puck clutch and 11lbs flywheel I dont want my car to rev faster because I will be getting a turbo
Old Dec 16, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
bull ****... u dont need to remove the sub frame... ive done it without doing it .. pull the tranny out the top.
Old Dec 16, 2003
CrewChief's Avatar
I'll say it again you ar a better man than I. I didn't even think of taking it through the top.
Old Dec 16, 2003
Ichiban's Avatar
Ichiban is an unknown quantity at this point
It helps me. I'm getting a new clutch and flywheel soon.
Old Dec 16, 2003
newshus's Avatar
newshus is an unknown quantity at this point
My friend works at Honda as a tech and he helped me change my clutch (Clutchmaster FX300 and 7.8 lbs flywheel) and it took us about 8 hours. We did drop the subframe per Honda instructions. Not a fun install to do at your own house. Definitely have a tech do it for you to get it done right. By the way, I LOVE THE CLUTCHMASTERS CLUTCH!!!
Old Dec 16, 2003
C2i0v0i1C's Avatar
SuperMODrizd
my shop adjusted it, its right smack in the middle
Blazz
Jun 4, 2015 01:04 AM
bsmiley
Apr 27, 2015 01:27 PM
tylerginevan
Apr 27, 2015 12:29 PM
cdt12271
Apr 23, 2015 11:36 AM
HitlistCivic01
Sep 20, 2001 12:09 AM
