Torque Coverter Bolts Sheared
Old Oct 4, 2020
Slash265's Avatar
Slash265 is an unknown quantity at this point
Hi all,
I recently replaced the engine in my 2004 Civic EX, and reused the old transmission. The new engine came with the flex plate still bolted on, so I used that instead of taking off the old one. I finished the swap, and everything seemed fine. I was able to drive for 20 miles or so, until getting off the freeway I lost all power. Car would not restart, only starter spinning. I figured I would need to replace the starter in order to diagnose whatever the other problem might be, but while I had the starter removed, I noticed I could spin the torque converter by hand, and I could crank the engine by hand and see the flex plate spinning separately from the TC.
I opened up the one of the shift cable covers and 5 sheared-off bolt heads dropped out. I think there's 8 bolts, so I hope they're in one of the other covers, rather than floating around in the transmission somewhere.
Has anyone experienced this before? What might have casued this? Should I not have reused the flex plate that came with the new engine? Should I have bought new TC bolts? I see now the installation method is to put the bolts in hand-tight in a crosswise before tightening all the way. I just tightened them as I spun the crank and the holes came into view. Was this a fatal error?
How f'd am I now - new TC? Flex plate? Entire transmission? Seems one way or another I would need to drop the trans - either to drill out the remnants of the bolts either from the flex plate or TC where they sheared, or to replace the flex plate/TC/trans as necessary. Is it even worth it to try to save anything, or should I just get a whole new (used?) trans and start over? Definitely with Loctite on these damn bolts next time.
Thanks!
Old Oct 5, 2020
Colin42's Avatar
Re: Torque Coverter Bolts Sheared
Were they torqued properly?
Check the condition of the flexplate and TC, you might be able to reuse them if there's no damage to the threads or the holes in the flex plate.
This happened to someone else a few months ago on here
Old Oct 5, 2020
Slash265's Avatar
Doubt it... I just threaded them in by hand and then tightened with a ratchet to "that's probably good" tightness, then spun the crank to get to the next one. No criss-cross pattern. Guess I'll be spending the next weekend or 2 fixing this. I found via the shop manual that the bolt thread is M6x1.0mm, but does anyone know the length?
Thanks!
Old Oct 5, 2020
BrotatoChip's Avatar
Super Moderator
That is exactly how I've done the ~4 I've ever messed with. Never had an issue Our arms must be calibrated differently.
14 mm. Here is the Honda part number if you are interested: 90014-P24-N00.
azure55
Feb 5, 2018 11:38 PM
dnmacdon
Sep 6, 2016 01:01 PM
Harrisrb51
Oct 23, 2013 12:51 PM
jblayz1
Nov 15, 2003 05:09 AM
4drcivic2k1
Sep 29, 2002 06:08 AM
