Replacing Studs with Bolts
Old Sep 3, 2016
dnmacdon's Avatar
dnmacdon is an unknown quantity at this point
Any issue with replacing studs with bolts in general? I'm reattaching the upper transmission mount, which is held on to the transmission with one bolt and two studs. Both studs came out with the nuts. I need to replace one. I can get a bolt today (in stock) or a stud and nut on Wednesday...
Old Sep 3, 2016
Re: Replacing Studs with Bolts
They may thread right back in the same way they came out. I'd run with this as my first try.
If you gotta use new bolts, make sure they won't be too long. You could crack the trans case if bolts are too long.
Old Sep 6, 2016
Colin42's Avatar
I just reused them when I did mine, didn't give me any problems
Old Sep 6, 2016
dnmacdon's Avatar
Thanks. One of the studs wasn't reusable (long story), the other would have been. Dealership had the nuts but said there was only one replacement stud in Canada (which they could get in a few days, and if I needed two it would be October).
What I ended up doing was overkill, but worked. I was at the junkyard for something else and pulled the studs off a Civic automatic, which are much longer on the top, same on the bottom. The nuts were frozen on, so I just cut them off under the nut, and they were about the right overall length, so I threaded them in and have "brand new" studs. Total time about 20 minutes and cost about $1.50.
Old Sep 6, 2016
Colin42's Avatar
Hey if it works it works I just swapped in another tranny so I had some spares
E Sully
May 1, 2016 11:57 AM
RIPSAW
Mar 12, 2016 12:14 PM
rollaguy
Suspension
Nov 11, 2015 07:48 PM
2k2civicballer
25
Feb 7, 2002 12:22 PM
veloce
Nov 10, 2001 01:19 PM
