Shi
Old Jan 7, 2020
Retiredmil48's Avatar
Retiredmil48 is an unknown quantity at this point
Shi
Ft linkage moves while replacing engine, now not going into gear.
please help.
Old Jan 7, 2020
GolNat's Avatar
Prelude Owner
Re: Shi
That's all the info you can provide?
Old Jan 7, 2020
Re: Shi
I put a new engine in car, when I hooked THE SHIFT linkage up the lever on transmission moved. Well I hooked UP EVERYTHING, now when I put it in gear , it's make a grinding noise.
do I have to reset the linkage on transmission and rehook the cable ??
Old Jan 8, 2020
BrotatoChip's Avatar
Super Moderator
Re: Shi
What year Civic?
You shouldn't have to reset anything as long as everything hooked back up properly. You did get the shift cable hooked back up to the trans shift lever and then the cable bracket bolted back down to the trans, right?
Mitchelatw87
Transmission
Dec 13, 2019 08:36 PM
Jayden Fischer
Mar 16, 2018 02:59 PM
turbo_96awd
Mar 29, 2016 05:27 PM
Srudet
Jun 7, 2015 09:34 AM
