Hard to Shift out of 3rd gear
Old Sep 16, 2019
quikrich3's Avatar
quikrich3 is an unknown quantity at this point
Question Hard to Shift out of 3rd gear
Hey guys,
I have a 2001 Honda Civic EX 1.7 vtec manual transmission that i had the clutch and input shaft bearing replaced on recently. All was great until i tried shifting "out" of 3rd gear... to go into 4th. I thought it was stuck, but it just took a firm pull to get it out of gear to, then, go into 4th. It goes into 3rd fine, but coming out of 3rd gear is the issue. Do you know what could have caused this? Is it the shift linkage?
Old Sep 16, 2019
Wankenstein's Avatar
Re: Hard to Shift out of 3rd gear
Possibly 3rd gear synchro issue? Has anyone recently checked (level) or changed manual transmission fluid?
Old Sep 16, 2019
Shifter pivot ball split open?
Old Sep 17, 2019
quikrich3's Avatar
When the input shaft bearing was replaced, I had him put new Honda manual Transmission fluid in it. I "personally" have not checked it. Is there a dipstick to check it?
Old Sep 17, 2019
quikrich3's Avatar
ezone, could you explain a little more as to why that would cause it to be hard to shift out of 3rd gear? Wouldn't it be that way in multiple gears?
Old Sep 18, 2019
This may help: https://www.civicforums.com/forums/3...-problems.html
Old Sep 18, 2019
No dipstick. There is a drain-hole (with bolt) at the bottom and a fill-hole at the top. Fill until fluid starts to drip from the fill-hole and then reinstall fill-hole bolt.
Old Sep 23, 2019
quikrich3's Avatar
Thanks for your responses... I'll check this tonight, and then i'll check the shifter ball. I'm just hoping it's not a transmission issue
grey2k11
Jul 23, 2016 01:55 PM
01civic20
Dec 16, 2013 06:52 AM
kal1fornia
Jan 13, 2012 12:45 PM
Civman500
Dec 23, 2010 03:21 PM
mrgadfly
Aug 21, 2010 07:16 PM
