manual trans shifting issue
hey everyone, i gotta 01ex manual, and it seems when the car warms up the shifting gets tighter. it doesnt slide into gear easily, it takes some force. when i shift from gear to gear it seems like its sticking somewhere, but there is resistance in it. if anyone can help your advice would be greatly appreciated. thanks!
Official Rattlesnake Hunter
Re: manual trans shifting issue
this may apply to you i dont know..
I think its the input shaft bearing or the syncrows...
http://https://www.civicforums.com/f...save-some.html
link didnt work for me
Got ya man, thanks!
Re: MANUAL TRANS STIFF CHANGEING GEARS.
Just figured out why my shifter on my 02 civic was stiff, gumlike when shifting throughout gears. There is a "hip like joint" just below the shifter that appears to have worn down enough as to bind during my shifting. I blew it out with air and sprayed some white lithium on the socket an ball of this hip structure. This immediately resolved the shifting issue. This may be a tempor. Fix as this probly is the result of wear, but until then it works great!!
oneheadlight
Apr 29, 2015 11:30 PM
davidpaustin
Apr 29, 2015 02:23 PM
