Leaking transmission fluid.
Old Aug 18, 2019
Tracecross30's Avatar
Tracecross30 is an unknown quantity at this point
im havong leaking transmission fluid coming from the area where you see the bolt hole in the green color.. Its a manual transmission. It seems the fluid running down and round up at that bolt area of the whlywheel cover bolt.does anyone have that problem can let me know where exactly where ots coming from.? I changed the cv axel seals on both side of the Tranny but I'm not sure where the leak is coming from to be sure.
Old Aug 18, 2019
Re: Leaking transmission fluid.
Give it a good wipe down with some degreaser then take it for a drive so you can find out where the leak is coming from.
Old Aug 18, 2019
Good idea.i never thi k of that.i will do and post a reply if i find out.thanks very much..
Old Aug 20, 2019
So I have oil dripping from my oil pan drain plug and I put new washer on there and tighten it to 33fb torque and it still dripping. What could cause it to still dripping?
Old Aug 20, 2019
mac25's Avatar
Dr Krieger of Modification
Since the plug sits at the lowest point on the pan, it may be run down from another area; if not, look at the drain plug gasket, make sure it is an aluminum oem style gasket.
Also look for stripped threads/worn threads.
Old Aug 20, 2019
Originally Posted by Tracecross30 via PM
So I just give it wipe down with some carb cleaner and with in 4 minutes I start seeing it running down from the CV axle area..my assumption is that the seal where the CV axle goes through to the transmission that's where the leak is coming from...I change the seals on both side when I rebuilt the engine and change the bearings in the transmission...
homie hit me up on PM. I have no answers other than to recheck the seals
Old Aug 21, 2019
It is an Oem aluminum gasket.i bought 2 oil filter and get 2 aluminum gaskets wth them.
Old Aug 21, 2019
Slumpertcivic's Avatar
Deleted
Though this was oil pan, not transmission plug.
Old Aug 21, 2019
BrotatoChip's Avatar
Super Moderator
I think he is talking about the actual oil pan.
Old Aug 21, 2019
Sorry to hsve you goes confused, but got an answer for the transmission leaking already..my apologies to post the oil pan issue under the same transmission topic..but I'm having the two leaks. I found out where tbe transmission leake is coming from..but im thinking if its the drain plug need to be change because i put a new OEM washer on there and im still have leakings.i can smell it burn each tine when got out the car.
Old Aug 21, 2019
Okay, what I deleted was I have seen multiple instances where one washer was stuck to the pan ( quick lube places love to put a smear of rtv on them) and then someone else installed a second washer on the bolt.
Double washers will seep and drip slowly.
Old Aug 21, 2019
Ok. I was thinking of using the RTV on it, get a new drain plug or an oversize one and put in.
nefliminator
May 28, 2015 10:18 AM
my89CIVICDX
Sep 27, 2013 12:55 PM
Steven21
Jan 16, 2011 11:47 PM
boosted2cam
Transmission
Jan 20, 2010 08:44 PM
claudeboi
Oct 16, 2005 08:39 PM
