Transmission Leaking
Old Jan 20, 2010
boosted2cam's Avatar
boosted2cam is an unknown quantity at this point
My tranny is leaking fluid pretty bad...looks like its coming from the driver side axle...its on my exhaust etc...splashing everywhere...
Im going to change the axle seal tomorrow...would i need to drain the tranny fluid out?
Autozone seals ok?
Old Jan 20, 2010
Re: Transmission Leaking
yeah just drain the fluid and fill it up with new. make sure the seals are installed properly otherwise it will still leak.
Old Jan 20, 2010
RonJ's Avatar
RonJ will become famous soon enough
Are you sure the leak is not engine oil, such as from the oil pan or rear main seal?
Old Jan 20, 2010
yeah there are alot of places for leaks. i have trans fluid all over the housing and underneath coming from the dipstick hole, and oil from rear main seal all over the oil pan. at first i thought the pan gasket was shot, but after cleaning up the mess with carb cleaner, i saw the pan was fine. just make sure you know exactly where its coming from cause its easy to see fluid all over and assume. our accord has leaky axle seal and the whole trans case is covered in oil due to fluid migrating different places.
Old Jan 20, 2010
i keep checking my engine oil seems fine...
the tranny is more wet then the engine so i think its the tranny
i will see. do i clean all the oil with carb cleaner?
Old Jan 20, 2010
yeah just spray it down carefully without getting it all over you. most of it should wash away.
mattdoc
Mar 14, 2017 12:10 PM
Kyrian
Jun 26, 2015 11:48 AM
97-DX-Lover
Jun 14, 2015 06:07 PM
nefliminator
May 28, 2015 10:18 AM
Richkid23
Apr 19, 2015 12:53 PM
