Sticky shifting
Old Jun 23, 2019
Tracecross30's Avatar
Tracecross30 is an unknown quantity at this point
Sticky shifting
So I changed all the bearings on my main and secondary shaft ,while taking off the bearings, some of the gears fell off so I had to put them back together,they put back together in the same order but now I'm getting a sticky shift when I'm trying go into 1rst and 2nd ,mostly second. It was very windy when I was working on outside and stuff was blowing everywhere so o dont know if its the debris causing sticky changing. The synchros are fine but I dont know.any ideas?
Old Jun 24, 2019
Slumpertcivic's Avatar
Re: Sticky shifting
Did you shift it through all the gears multiple times before you put it back in the car?
Old Jun 24, 2019
Re: Sticky shifting
Yes I did all that and it was going through them just fine and smooth as well. When I sink the clutch all the way to the floor it still giving me that sticky feeling.. my clucth is high so I have no doubt that the clutch is the cause of that but I could be wrong because I'm not professional in this field. This morning got to work and was trying to park it in gear and when ease my foot off the clutch thinking that it's well parked in gear,I feel it running back and I hear like the are grinding while it going backwards. It dont happen all the time though. And when I'm driving and changing from 1st to 2nd I hear a little grinding. All this never happened before I opened the gear box. I opened it because some bearing was bad and making noise so I opened it to fix it. The noise is gone but this happening now.
Last edited by Tracecross30; Jun 24, 2019 at 07:30 AM. Reason: Give more information
jasonauslander
Sep 4, 2014 12:19 AM
GreenFamily
Transmission
Jun 18, 2011 10:41 PM
texas-civic
Buy, Sell, & Trade - Archive
Feb 3, 2007 10:37 PM
GoNeIn60
May 7, 2005 10:29 PM
armieo
20
Apr 6, 2004 09:04 AM
