HELP: steering wheel is creaks while turning
can anyone tell me why everytime i make a left turn, and sometimes right.. at a certain spot in the turn its making this creeking noise? it sounds like its coming from behind the steering wheel. how do i fix this?
GET UNDER YOUR CAR AND CHECK OUT YOUR CV BOOT if it is ripped then more than likely its your cv joint is bad. the cv boot keeps grease in and dirt out. the cv boot looks like a black rubber accordian thing. this isnt a pic from our car but just to give you an idea.
now you should get this replaced as soon as you can but if you cant afford it you can get a cv boot like item with a zipper on it and just cram that thing with grease every few days.
still everyone should check their cv boots on a regular basis like every time you change the oil. just make sure their are no rips or holes in it. typically a bad cv joint will sound like a clicking noise.
yeah, my cv boots are fine, one of them tore but warranty covered it. the noise, for me is more of a squeaking, and it sounds like its coming from the steering column.
Jspek Inspired
ok, its not the cv boot lol. Take some white grease or silicone spray to lube the steering link boot that goes through the firewall from the drivers side. after you squirt some in rotate the steering wheel left and right. That should get the squeak to go away.
Proud to be a civic owner
i just found out i have a similar problem.. are you guys like when you turn, the steering wheel is kinda stuck??? mine is like that... hopefully it's not something major, taking the car to the dealer next sat.. (btw, my warranty is expired)
everytime i turn the wheel all the way either to the left or right there's a sqeeking noise...WTF IS THAT? I need to know what it is so i can take it in to the dealer since my car is still under warranty.
Re: HELP: steering wheel is creaks while turning
My 2013 Honda Civic also makes a noise, noticeable when first using the car, at low speeds. I think of it as a piece of paper
stuck behind the wheel. It's not squeaking or creaking but sounds like paper or stiff fabric.
I switched my power stearing fluid it with Automatic transmission fluid, didn’t know it was a thing, it is supposably easier on the pump, I just does that when it’s cold now
SkiLLzSter
Apr 18, 2012 12:15 AM
rickywf
Nov 10, 2011 01:35 AM
Thrasher086
Oct 13, 2006 07:23 AM
fuzzylogic426
Aug 31, 2005 10:56 AM
