Electronics Post your electronic questions here!
Remote Locks Not Working As Intended
Old Aug 26, 2024
Jeanelliellie's Avatar
Mother of Vicci
Jeanelliellie is an unknown quantity at this point
Hey all,
I recently purchased an 02 EX coupe, and I'm having an issue with the remote locks. The car didn't come with a remote, but I knew the car probably had it bc of the trim level. So I bought one off eBay, programmed it to the car, and now it works... almost. Pressing the unlock button will unlock the passenger side door but not driver side's, while the lock button doesn't lock either. The vehicle makes some sort of clicking/lock mechanism noise for each button press, however. Also, the interior lock/unlock doors switch doesn't affect the driver side either.
Anybody know where I should start with troubleshooting/fixing this? Thanks!
Old Aug 27, 2024
Colin42's Avatar
Re: Remote Locks Not Working As Intended
Drivers actuator might be bad. Might be broken wires in the door harness
Old Aug 27, 2024
Mother of Vicci
That makes sense, I'll make sure to take a look at that. I'm going to look up how to bench test it, but any wisdom on doing it before?
Old Aug 27, 2024
they break at the hinges with the constant door open/close over 20+ years. spread legs (woups, doors) wide open, pull off the rubber boot and check wires.
Old Aug 28, 2024
Colin42's Avatar
Apply 12v and ground to the actuator and see if it functions
sdnomad
Electronics
21
May 30, 2023 11:46 AM
Rawr.monsters
Feb 28, 2016 11:05 AM
bmnot
Jul 25, 2011 03:42 PM
mister2
Jan 3, 2010 04:49 PM
icedcoco
Feb 21, 2005 09:30 AM
