Electronics Post your electronic questions here!
No Start after Clutch replacement
Old Feb 25, 2024
Cbarber253's Avatar
Cbarber253 is an unknown quantity at this point
Exclamation No Start after Clutch replacement
Ok, so really need some help. I can't figure this one out.
I have a 2004Civic si. The clutch went out and I replaced it.
After reassembly, I cannot get it started. The starter clicks but won't do anything else. Had the battery tested, it is perfect. looked at all the wires and can't find where I missed something.
I did not disconnect the starter from the engine when replacing the clutch, nor did I replace the flywheel.
Anyone have any ideas? I
Old Feb 25, 2024
TokyoCornflower's Avatar
TokyoCornflower is an unknown quantity at this point
Re: No Start after Clutch replacement
Have you turned the engine over manually and confirmed it will do so correctly/run? Have you checked if the clutch is able to disengage (If it isn't, the starter may not be able to shift the entire vehicle and engine cold)? I don't really know what might be going on, but maybe something will stick to the wall.
Old Feb 26, 2024
no ground cable knocked out during clutch job?
Lilslamdcivic
Apr 30, 2018 09:16 AM
Mckenneth
Dec 9, 2017 08:42 PM
DarkSouljur
22
May 6, 2011 08:48 AM
pnamajck
Jan 8, 2011 07:07 PM
TheNick
Sep 14, 2005 02:56 PM
