Anyone by chance know?
Old Apr 28, 2018
Lilslamdcivic's Avatar
Lilslamdcivic is an unknown quantity at this point
Car currently not running . No crank no start...tried push starting it , and as i was letting go of the clutch the car came to a complete stop..anyone know what the problem might be ? Thanks in advance .
Old Apr 29, 2018
GolNat's Avatar
Prelude Owner
Re: Anyone by chance know?
CEL on?
So the starter doesn’t even try to turn the engine over? Might be the starter?
Clutch switch would keep it from starting.
Old Apr 29, 2018
Wankenstein's Avatar
Look for rubber pieces on the driver side floor mat. The clutch switch is contacted by a rubber bump-stop that's inserted into the top part of clutch pedal mechanisim. This rubber piece can fall out intact or degrade and come apart. Here's a related read: https://honda-tech.com/forums/honda-...witch-3223061/
Old Apr 29, 2018
CEL on?
no CEL. Switched starter out with one that worked from my ej ,but had sitting for about a year . Not sure I'd it wold go bad. But no luck.. checked clutch switch it seems to be okay .. car stopping from trying to push start it may be a seized engine or no?
Old Apr 29, 2018
I had a seized alternator that made my engine die and not turn back on once. Wouldn't hurt to make sure all accessory pulleys spin freely
Old Apr 29, 2018
Don't use 1st gear for push start. Use 2nd or 3rd.
Open hood. Put trans in 5th and push car from the front while watching the pulleys and belts. Does engine spin (belts and pulleys rotate) as you move the car? (OR rotate crank using tools)
Any accessory that is locked up can stop the engine from turning too.
Old Apr 30, 2018
Thanks guys. Pulled the engine and took the block apart and found out it spun a bearing
Danger Mouse
Texas
Feb 22, 2005 08:27 AM
CivicChick2k1EX
Jun 8, 2002 01:51 PM
Rollin0n18s
Jun 5, 2002 04:00 PM
black2k1vtec
Feb 7, 2002 01:24 AM
Voiceofid
Feb 3, 2002 03:54 PM
