Electronics Post your electronic questions here!
Replace gauge cluster?
Old May 27, 2022
sdx3812's Avatar
sdx3812 is an unknown quantity at this point
I have a 2001 Civic DX. My speedometer is stuck at 0. I'm pretty sure its the gauge since the ODB2 reader shows the correct speed (And the odometer goes up).
Since I am going to replace the gauge cluster, can I replace it with one that has a Tachometer? My current gauge cluster doesn't have one.
Also, if I replace the gauge cluster, will the Odometer show the wrong reading?
Old May 27, 2022
Colin42's Avatar
Re: Replace gauge cluster?
I think as long as you use a cluster from 01-03 it should just plug in and work. Obviously the mileage will be wrong, depending on where you live you may have to document the different mileage
Old May 29, 2022
sdx3812's Avatar
Ok, thanks for the info.
Old May 30, 2022
01-02 cluster. They gave the cluster a facelift in 03.
The 03-05 cluster works if you wanna re-pin your gauge cluster plugs. I planned on doing that but never got around to it.
Old May 30, 2022
sdx3812's Avatar
Luckily I ordered a 2001 cluster. Thanks.
Also, do you know how easy it is to set the correct the mileage on the odometer? Do I need to take it to a mechanic to do?
Old May 30, 2022
I think you have to find a specialized shop. That was one of the things holding me back on the cluster swap project
Old May 30, 2022
sdx3812's Avatar
Thanks, I'll try to find a shop to do it.
Megas
Jan 14, 2011 04:30 PM
lbergenthal
Jan 7, 2011 02:13 PM
sethro
Oct 18, 2008 03:26 PM
LnkinParkPunk
Mar 18, 2003 04:57 AM
power091999
Sep 30, 2002 09:09 PM
