Electronics Post your electronic questions here!
Dimming power
Old Oct 23, 2021
jwboucher94's Avatar
jwboucher94 is an unknown quantity at this point
Dimming power
I've noticed a slight dimming in the headlights and cabin lights - not a constant dimming, but a flickering from high to low and back. At idle or at drive. Do i need to replace the battery, or the alternator? I need to tighten my belt a little bit because it was new and I've driven a bit, makes a squeal when the ac is on. Is it because of that? I'd really like to not replace the alternator that ***** expensive. Hasn't had trouble starting ever or anything like that.
Old Oct 23, 2021
FRSam's Avatar
Click Here
Re: Dimming power
What car do you have?
Old Oct 23, 2021
Re: Dimming power
Suppose that would have been smart to mention. 02 civic EX
Old Oct 23, 2021
Re: Dimming power
have someone test:
  1. battery (how old is it?)
  2. alternator (after you tighten belt)
Old Oct 23, 2021
Re: Dimming power
the belt squeal and your dimming "issues" are likely not related, just coincidentally occurring
Is it just a slight dimming, but noticeable? Like, when you're under load, you have full brightness, but when you start coasting or at idle, it seems to dim? If so, that's somewhat normal behavior. That's the ELD doing its thing as a sort of fuel saver method. Hook up something to monitor battery voltage, and if you see something like 14-14.2V at full load and then down to 11.9-12.1V at idle/low load, then you're fine. If you're worried about components having issues, get them tested before replacing them. I know AutoZone does free testing on both batteries and alternators.
Old Oct 25, 2021
bachands's Avatar
bachands is just really nicebachands is just really nicebachands is just really nicebachands is just really nice
Re: Dimming power
You have to do some testing to know for sure, but my experience was...
Wisconsin winter. Noticed the headlights would dim every now and then while the car was running around November. Car had around 134K miles with the original alternator. I thought maybe it was because of the cold or a weak battery, but didn't think much of it since the car always started fine.
In February, the car just stalled on my way to work. It was a bad alternator.
What's the mileage? Is it the original alternator?
msaeger
Sep 2, 2015 08:47 AM
RobertK
17
Nov 9, 2012 11:20 PM
ericli007
Oct 10, 2012 10:34 AM
Simbashi
Dec 15, 2009 10:34 PM
Sparks23
Aug 22, 2007 02:06 AM
