No power getting from the alternator
Old Aug 1, 2007
Sparks23's Avatar
Sparks23 is an unknown quantity at this point
Alright here's the situation:
I recently bought a '98 Civic 2 door coupe. Car has had either a head or full motor swap because it has a vtec-e head in a non-vtec car.
But here is the problem: There is no power getting from the alternator to the battery. The car starts when jumped and runs/drives fine but drains the battery as you drive and won't start again on its own after you turn it off. My boyfriend and I just replaced the alternator and put a new battery in it... still no voltage. All the belts are fine and the plug that goes into the alternator is showing 5v/12v/12v/12v on the four terminals in it. And all the rest of the wiring appears fine
I could have just gotten a bad alternator, in which case I will return it and get a new one. I'm thinking it may have something to do with the wiring though. Does anyone have any other ideas as to what it may be?
Old Aug 9, 2007
Physpher's Avatar
Physpher is an unknown quantity at this point
Re: No power getting from the alternator
i have an 03 ex and i replaced mine and it will not put out more than 12v. starting to irritate me as well. still havent found out why its doing that.
Old Aug 10, 2007
urwhat's Avatar
urwhat is just really niceurwhat is just really niceurwhat is just really niceurwhat is just really niceurwhat is just really nice
You could possibly need new battery to alternator/battery to ground/chassis to engine block cables. A poor connection might be stopping current from flowing correctly.
Another good chance is that you have a bad alternator/wrong alternator. exchange it. Unless its Honda OEM, alot of those rebuilt ones have some issues.
Old Aug 22, 2007
mneuls's Avatar
mneuls will become famous soon enoughmneuls will become famous soon enough
I had to tighten the belt on mine, it was slipping under heavy load. I have also heard that there is some kind of voltage regulator that could be gone, but I know nothing about it.
jzhartman
22
Jul 23, 2015 10:42 PM
jzhartman
Jul 9, 2015 04:56 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
hayden55
Jul 8, 2015 11:38 PM
cgavin1
Jul 7, 2015 07:10 AM
