Electronics Post your electronic questions here!
2003 Civic ignition switch. Used OEM or aftermarket?
Old Nov 23, 2019
cyber1's Avatar
cyber1 is an unknown quantity at this point
Hello.
The ignition tumblers are totally shot in my 2003 civic. The dealership wants an astounding $800 to replace it. I can get a knockoff one on Ebay for $60 and install it myself, but my dealer said that because it isn't OEM, there would only be a 50/50 chance they would be able to program the key. Does that sound right to you? Here's the knock ignition switch I'm referring to:
https://www.ebay.ca/itm/Ignition-Swi...909944315658af
Would you risk getting that one and hope the dealer can program the key, or would you find a second hand OEM ignition switch?
Old Nov 23, 2019
Colin42's Avatar
Re: Need new ignition switch. Used OEM or aftermarket?
Just take the tumblers out, you'll be able to turn the switch with a screwdriver but because of the immobilizer it won't start without the key. No programming needed.
Old Nov 23, 2019
Slumpertcivic's Avatar
Re: 2003 Civic ignition switch. Used OEM or aftermarket?
Or if your super retentive , buy a Honda High Security Pinning Kit (A-19-108) for $80 and replace all the pins and springs in your lock and keep your key.
Old Nov 24, 2019
cyber1's Avatar
Thanks for the replies.
Just addressing the tumbler itself seems to be the best way to go. I'm going to try getting it out today, then call some local locksmiths to see if they can repair it. If not, I'll order the pinning kit.
Old Dec 15, 2019
cyber1's Avatar
That's exactly what I ended up doing. It took a little a "MacGyverying", but after an hour and a half, I had her running and saved $800.
Thanks!
lynlan
Aug 16, 2018 12:04 AM
stahlpb
Jul 29, 2018 07:22 PM
cheryl
Apr 4, 2018 09:53 PM
generye
Sep 23, 2013 11:44 AM
blackhondacivic
Aug 25, 2012 12:34 AM
