Electronics Post your electronic questions here!
Need help with Key Fob programming
Old Nov 16, 2019
osky1976's Avatar
osky1976 is an unknown quantity at this point
I'm a Newby so please don't drill me on this. I purchased a car that came with no key fog. I bought an OEM used key fob from ebay.com. I went by the instructions and can't program it to save my life. I tried four times as what the instructions say and on the fourth its supposed to lock the doors ect. Well it doesn't . As I sat in my car trying to figure this one out above the rear view mirror there is this thing that looks like part of the alarm system. I press the button and it lights blue and I can turn it off . I have no idea what that does. can someone explain what this is and what else I can try to get my key fob to work. I put a new battery in it, when I press the button it lights up.
Old Nov 16, 2019
osky1976's Avatar
Re: Need help with Key Fob programming
I also made sure the doors were closed as well when trying to program.
Old Nov 18, 2019
BrotatoChip's Avatar
Super Moderator
What year and trim Civic do you have?
Old Nov 18, 2019
Colin42's Avatar
That sounds like there's an aftermarket remote start/alarm installed. Your car may not have factory keyless entry. If you can find the remote start module and get a brand and model number you might be able to get remotes for it. The programming procedure is different
Old Nov 18, 2019
GolNat's Avatar
Prelude Owner
Does the blue light thing look like this?
Lower trim level generally didn't have key less entry. Sounds aftermarket though.
Old Nov 18, 2019
osky1976's Avatar
Yes it looks like that, My Honda is a 2004 Civic EX Automatic coupe.
Old Nov 18, 2019
GolNat's Avatar
Prelude Owner
That's an aftermarket antenna. Look under your steering column for a module.
That particular antenna is a DEI brand one. Viper, Clifford, Python are the popular DEI brands.
EX should have factory key less but it may have been removed for the aftermarket system.
Old Nov 18, 2019
osky1976's Avatar
Snap. ok I will look for it tomorrow.
J9 Brian
Apr 5, 2015 10:56 PM
CraigW
Apr 14, 2014 09:32 AM
sijen
Jan 7, 2013 05:41 PM
roger t
Feb 25, 2009 07:50 PM
954rr coupe
Dec 7, 2006 08:39 AM
