Electronics Post your electronic questions here!
Key fob
Old Oct 18, 2019
Kianeush's Avatar
Kianeush is an unknown quantity at this point
Key fob
Hello, I have recently installed a stereo into my girlfriends 2004 Honda Civic si and ever since we did that the key fob will not work. We tried resetting it and re programming it and it still isn’t working. Also when the car is not in the on position (where the lights turn on) the door lock button on the inside does not work. Anyone know how to fix?
Old Oct 18, 2019
BrotatoChip's Avatar
Super Moderator
Re: Key fob
Check fuses 9 (10A) and 16 (20A) in the under-hood fuse box. Number 9 is also battery power for the radio, I suspect you accidentally blew the fuse while installing the new radio.
Old Oct 18, 2019
Kianeush's Avatar
Re: Key fob
There is power for radio as it is working fine, I’ll try checking 16 later.
Old Oct 18, 2019
Super Moderator
Re: Key fob
The radio would still work without fuse 9 as it has a separate ignition supply. Still check fuse 9.
Old Oct 18, 2019
Kianeush's Avatar
Re: Key fob
Okay I’ll check fuse 9, fuse 16 is all good though.
thesupersoap33
General
May 29, 2019 06:13 PM
SpeedReeeser516
Apr 3, 2018 11:02 PM
Hondacivic12717
Mar 7, 2018 05:42 PM
Amandag13
Oct 15, 2016 03:34 PM
sijen
Jan 7, 2013 05:41 PM
