Electronics Post your electronic questions here!
Remotes won't lock doors but unlocks doors
Old Nov 30, 2009
sdnomad's Avatar
sdnomad is an unknown quantity at this point
I bought a 2004 civic lx and it did not have the remotes. I bought 2 used remotes and programming the remotes went fine. But after they are programmed, the unlock buttons works, the panic buttons work, but the lock buttons do not do a thing. I know the lock buttons are sending a signal because I pushed them when programming the remotes and the locks cycled like they should.
Any ideas what might be the cause?
Old Dec 1, 2009
CraigW's Avatar
Re: Remotes won't lock doors but unlocks doors
Are all the doors closed and key out of ignition when attempting locking ??
Do they lock o.k. when the drivers door is closed when using the lock/unlock button on the door ??
Old Dec 1, 2009
sdnomad's Avatar
I have all the doors closed and key out of the ignition. I'm standing outside the car pushing the lock button on the remotes and it will not lock. If I push the drivers door lock down, all doors lock automatically. When I push the the unlock button on the remotes, it will unlock doors.
And the lock/unlock on the drivers door works fine.
Also, the interior light does not come on when drivers door opens. I don't know if that has anything to do with the lock buttons on the remotes not working.
Old Dec 1, 2009
CraigW's Avatar
It may, check the black rubber covered plunger switch in the drivers door jamb. 1 screw to remove. It has a single wire.
They are easily broken.
You can use the passenger side switch to swap for testing, they are the same.
Old Dec 1, 2009
yeah, if the dome light isnt working, your door switch is prolly broken, and the keyless thinks the door is open (and if the door is open, it will not lock the doors as a safety feature).
Old Dec 12, 2009
sdnomad's Avatar
I should have said the dome light does not come on when any of the 4 doors are open. The dome light bulb is good because it does come on when the dome light is switched to on.
Old Jan 30, 2012
biobot93's Avatar
biobot93 is an unknown quantity at this point
this is the exact same thing happening to my car. mine have worked perfect for the last month until tonight. more help would be much apperciated!
04 EX em2 sedan
Old Jan 30, 2012
04 Honda Civic's Avatar
If I am not mistaken, each button is programmed individually?
Old Jan 30, 2012
lazlong's Avatar
04 EX em2 sedan
Just check the door button(s).
Old Jan 31, 2012
biobot93's Avatar
this makes no sense to me, if it thinks the door is open, then why does the drivers side door lock when you push it down. or why isint the open door indicator on the dash on?
Old Jan 31, 2012
biobot93's Avatar
i fixed mine, turns out it was one of the other doors that were open. so check your other door switches as well as the drivers
Old Jan 31, 2012
Haha, who would of knew..
Old Jan 31, 2012
lazlong's Avatar
From my earlier post- "Just check the door button(s)."
Old Aug 13, 2013
astateofmind's Avatar
astateofmind is an unknown quantity at this point
Hello,
i have a similar problem: when i unlock the doors it works, when i try to lock them using the controls it fails, i can hear 2 clicks from under the dashboard but nothing happens.
I had the same problem with the dome lights so i figured that there was a problem with the door switches, checked them - one was not in his place so i put it back and now seems to be ok with the dome lights: when i open a door it lights up (before it didn't) when i close it it shuts but the doors are still not locking with the controls. I supposed it still detects my doors as being open somehow.
Any ideas?
Thanks.
PS: the car is a 2001 Civic.
Old Oct 12, 2017
rwatson's Avatar
rwatson is an unknown quantity at this point
Re: Remotes won't lock or unlock doors after programing my 2001 honda civic coupe 2 d
remotes
Old Aug 16, 2018
Trino's Avatar
Trino is an unknown quantity at this point
Could this also make the engine light come on? My doors are doing the same thing and it happened same time my engine light came on.
Old Aug 16, 2018
Colin42's Avatar
Nope not related whatsoever.
either buy a scanner or go to a parts store to have them read the codes. Post a new thread with the code numbers Pxxxx format.
Old Aug 17, 2018
Trino's Avatar
Ok thanks. I will do that.
Old Oct 8, 2019
Ray jr's Avatar
Ray jr is an unknown quantity at this point
I have similar problem, when I try to lock my doors with remote all doors lock besidea the driver door. Any suggestions?
Old Oct 8, 2019
BrotatoChip's Avatar
Super Moderator
Possibly a bad lock actuator. You will need to remove the door panel and check if the actuator is getting power/ground when it should.
Old Oct 8, 2019
Colin42's Avatar
Could also be broken wires in the door harness
Old May 30, 2023
Juliarb's Avatar
Juliarb is an unknown quantity at this point
Thank you for the suggestion regarding one of the doors not being properly closed as I also had been having my key fob work as usual to unlock but not to lock the doors. The boot open indicator light was showing as something was jammed in the boot door when closed so although the boot was essentially shut, it was triggering the boot open indicator. It would never in a million years have occurred to me that this would stop the key fob from locking the car doors! Much appreciated for the helpful advice.
Rawr.monsters
Feb 28, 2016 11:05 AM
bmnot
Jul 25, 2011 03:42 PM
Obamargarine
Nov 17, 2009 06:55 AM
BADFNZ
Jul 9, 2007 09:57 AM
Maple50175
Jul 6, 2007 12:16 AM
