My door can only lock with a key
Old Nov 16, 2009
Obamargarine's Avatar
Obamargarine is an unknown quantity at this point
This is really weird, guys: the driverside door won'y lock with the button, and I can't lock it by pressing the lock manually, so I don't know if it's a broken actuator.
The only way to lock it is from outside with the key.
How do you fix this?
thnx
Old Nov 16, 2009
CraigW's Avatar
Re: My door can only lock with a key
The drivers door will not lock when it is open, the lock **** will not go down.
How about if you sit in the car with drivers door closed and push the lock button or the lock **** down ?? Does it work then ??
It should lock when closed by doing either, it should also lock the other door(s)
Old Nov 16, 2009
sl33pyriceboi's Avatar
ur actuator is blown. usually the driver goes out first... there is a DIY on here, search for it, its an easy fix, jsut time consuming.
Old Nov 16, 2009
Foffie's Avatar
Im a Senior Member. Take that Noobs!!
Foffie has a spectacular aura aboutFoffie has a spectacular aura about
and just so ya know the passenger side is prolly not far behind from going out
Old Nov 16, 2009
Spill2can's Avatar
Spill2can is an unknown quantity at this point
I have the same problem, i dunno if it is mechanical. If you hold the door handle open and push the lock button down it will lock from the inside. Works on my 01 Lx
Old Nov 17, 2009
CraigW's Avatar
The fact that it won't lock when open is the very old method Honda uses to keep you from locking yourself out. It is a normal function.
I have used this method a few time on my 05 but it somehow gets in a weird locked up state that freaks me out so I quite doing it ( I sometimes like to lock the car with it running and use a 2nd key to get back in)
The best way to check actuators is use the power lock button (drivers door closed) they should both go up and down quickly. Another good test is when you use the keyless to lock/unlock, the pulse used is just a bit shorter. If the lock ***** are sluggish or there are noises when you 1st try them it is a sign.
The one on my passenger side would work fine for a while if cycled it a few times but got very slow when 1st used later. Eventually it would sometimes not lock completely.
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
h4ldol
Jun 28, 2015 10:18 PM
bluedoggy1
Jun 20, 2015 11:25 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
CaseysGuy385
Jan 21, 2002 08:44 AM
