Hydrolock
Old May 18, 2003
Ike's Avatar
Ike
Ike is an unknown quantity at this point
Exclamation Hydrolock
Last night at about 3:00 am I was on my way home from getting some food when my car just stalled. It was raining hard as hell. I have an Injen CAI with no bypass . This guy helped me out by pushing my car with his truck I was able to get it to turn over, I just had to make sure my RPMs didnt drop. So I drove a little further and it shut off again. This time no sign of life. There was a slight burning smell, so I just put it in neutral and some guy pushed me to a parking spot. OWN3D! I called a friend of mine to take me to my house. I will most likely need to either rebuild my engine or get a new one.
So my question is: I have an 02 LX, should I get an EX engine. From what I have heard the EX is significantly slower than the LX. Would all I need is the engine and the ECU? If I keep my LX tranny the differentials would be better wouldnt they? Also if someone could send me a link to a site that sells engines I would appreciate it.
Oh, and I cant afford an K swap.
Old May 18, 2003
Ike's Avatar
Ike
I just got home from trying to start my car. It wont even turn over. The fan works though.
Any advice would be appreciated.
Old May 18, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Same thing happened to "iceman" from SoCal.
The EX engine isn't significantly slower... one of the reaons why the EX models are slower than LX is due to weight. EX has moonroof and other cool gadgets that just slow the whole car.
IMO, just get an LX engine and save yourself headache. If you get an EX engine, i'm pretty sure you need a new ECU to activate the (almighty) VTEC.
Good luck!
Old May 18, 2003
Ike's Avatar
Ike
Does it make any sense to try and jump it, having somebody push it? What further harm could it do?
Old May 19, 2003
Weaponx12o's Avatar
doesnt hurt to try
Old May 19, 2003
R3DL1N3's Avatar
EX VTEC > LX NON VTEC....duh
the ex engine is more powerful than the lx, but the lx is lighter and doesnt have the amount of accesories as the ex.
Old May 20, 2003
Cdub8420's Avatar
Cdub8420 is an unknown quantity at this point
definitely forget about the whole jump starting it thing. I hydrolocked a ex coupe, using a injen CAI and had to replace the whole motor.
broke connecting rods for all 4 cylinders, and bent my crankshaft.
I was also at 5 grand when it happened. Insurance company sued Injen for not even producing a Bypass valve, got money back, insurance claim off my record. good luck IKE
Old May 20, 2003
ak's Avatar
ak
Retired Mod
wow, your insurance paid for it? lucky you!
iceman had to dish out like $2200 total.
Old May 20, 2003
Ike's Avatar
Ike
Today we went and took the spark plugs out hoping the we could get it to turn over and shoot water out, didnt work. Then we tried letting the water out of the oil pan, didnt work. So I am definetely gonna need a new engine.
I have full coverage and tomorrow I am gonna go put my stock intake back on. I will prolly try to get an D17A2, we'll see. I talked to the insurance company today and they said I need to get it towed to a shop and they will write me a check for the cost of that. They also said they will cover it and I will have to pay a $500 deposit.
Old May 20, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
The EX is not slower than an LX because of extra weight. The gear ratios are different, which may do it, but if you run the numbers....
LX weighs 2474 lbs with 115 HP... 1 HP must move 21.51 lbs. EX weighs 2554 lbs with 127 HP... 1 HP must move 20.1 lbs. All numbers from Honda.com (I punched the ratios) So an EX engine in an LX would be faster than an EX, but the extra weight of the sunroof is not enough to make the car slower... I can't remember what the final drive ratio is... that might do it, but I don't think an EX is slower than an LX if you have 2 people who know how to drive. Chances are.... you'd race to a draw.
Old May 22, 2003
david02civic's Avatar
I'm The Shit
david02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusted
SO i have an Injen intake now and if my engine Hydrolocks my insurance could sue Injen to replace my engine?OH, and boilmaker, i drive a DX and my car was completely stock (except 17" rims and body kit, no engine mods) and i killed an EX with exaust and header . both of us can drive good, both 5 speed and by oursleves in the car. My car weighs alot less than the EX but you pay for it when you have to lok ghetto rolling up the windows. lol
Old May 22, 2003
Cdub8420's Avatar
david...... i do not know how your insurance company would handle that, just get yourself a bypass valve, save the time and effort. I had to fight like woah to get a NEW engine, and not a reman....
if you need a good deal on a bypass valve, let me know
Sleepersperformance@attbi.com
see ya
Old May 22, 2003
Jap-Euro Fusion
You obviously missed everything I said because I was on the money...
The EX final drive is 4.411
The LX/DX final drive is 4.111
THAT is what accounts for the LX possibly being faster. Once instance doesn't mean ****. You need at least 3 occurances for something to be scientifically justified, more is better.
The weight has nothing to do with it because I've already proven with numbers and equations that the EX has more than sufficient extra power to overcome its weight disadvantage, however the taller final drive that allows it to cruise at lower RPM (of sorts) keep it from accelerating as quickly. And an Intake and Header do nothing, so that doesn't matter at all.
Go ahead if you still don't believe me and prove me wrong. Prove with numerical fact that the extra 80 Lbs makes the difference. Even with the less weight in a DX, the power to weight is still 20.88 LB/HP, which is still higher than the 20.1 Lb/HP of an EX. So now you're drawing basically dead even as far as power goes... so what's left... The drive train... lower final drive makes the difference, exactly like I said up above. Besides that, there are still too many extraneous factors to consider.... a Gallon of gas weighs about 8 lbs... did you add that in? What about what you weigh? **** in the trunk? All things totally equal, the cars should run dead even.
Old May 22, 2003
ak's Avatar
ak
Retired Mod
Thanks for the explanation boiler, i didn't think of the gear ratios.
Old May 22, 2003
I'm The Shit
excuse me.i didnt read all of it. I dont have ant audio equipment and nothign at all in the trunk and had a full tank of gas
Old May 22, 2003
I'm The Shit
hey Cdub8420, i emailed you but no answer.
Old Jun 10, 2003
Ike's Avatar
Ike
FYI: I got my car back today!
Old Jun 13, 2003
jonfin's Avatar
jonfin is an unknown quantity at this point
Ike your lx is slow lets just leave it at that because whoever told you that the ex was slower than the lx they have been sittin down with their finger in their *** for too long!!!
Old Jun 13, 2003
jonfin's Avatar
The 2002 civic ex has 137 hp 1.7 liter V-tec motor known as a D17. Not 127hp.
Old Jun 13, 2003
ak's Avatar
ak
Retired Mod
oh yea?? honda.com says 127hp known as D17A2
jjdawg22
Aug 15, 2005 10:59 PM
bgoetz
May 31, 2005 01:46 PM
NoToRiOuSxPiNoY
Aug 26, 2003 07:36 PM
DaPipeLayer
Jul 18, 2003 04:46 AM
jpan_home
18
May 6, 2003 09:59 AM
