Could this cause issues with compression?
Old May 29, 2024
jcov14's Avatar
jcov14 is an unknown quantity at this point
Unhappy Could this cause issues with compression?
So I did a compression test on my 03 civic and this was the result
CLY 1 -125-127psi
CLY 2 - 50 psi
CLY 3 - 24-26 psi
CLY 4 - 160 psi
after removing the spark plugs I looked down the cylinders and 1&4 were squeaky clean like shiny brand new metal. I could see the valves. 2&4 were extremely dirty. I wondered if that would be why the compression is low. Some people have said put oil in the cylinders and see if compression goes up, some said use seafoam spray in the cylinder. I want an opinion before i go spend extra cash to work on it.
Old May 29, 2024
Colin42's Avatar
Re: Could this cause issues with compression?
Head gasket is most likely blown between 2 and 3
Old May 29, 2024
and possibly some ring issues on 1 considering 4 is getting 160 psi and 1 is only at 12x psi
Nov 22, 2016 07:27 AM
laack
29
Jun 17, 2010 03:29 PM
AequitasVeritas
May 7, 2007 11:54 PM
torqen2k1
Mar 31, 2004 06:11 PM
MangoEX
Dec 24, 2002 12:09 PM
